Frame rust issue
Really the rest looks ok...I think this happened at this point because of a battery leaking issue or something of that nature..maybe a leaking radiator at one point
Question is how do I fix it correctly?
If you must build it up by plating over top, you can thin the bushings a like amount, but it would be some guess work as rubber will compress.
A leaking radiator leaking anti freeze with rust inhibitors is one thing, a radiator leaking water is another ... but a leaking battery ... is bad. A dead battery can freeze and bust, a dropped battery can bust too.
As far as the driver's side, can I get the mount off without cutting through it?
The bushing steel parts are pressed together as installed. There are many threads here where guys measured and just made new from steel water pipe and washers from like "Lowe's". A single thick piece of steel bridged across two blocks of wood might do it inside that frame rail?
Thanks for the info
https://shop.broncograveyard.com/197...ctinfo/23069A/
Fix rusted out body mount holes with this product. When you are replacing body mount bushings and you discover the holes on your body mount brackets are rusted or thin, this product is for you. Just cut away bad metal and weld on the new frame saver.
2-3/4" OD
1-7/16" IDThis Product Fits the Following
1978, 1979 Ford Bronco
1973, 1974, 1975, 1976, 1977, 1978, 1979, Ford F100, F150, F250, F350
2-3/4" OD
Thanks...I saw these earlier..just ned to measure to see if I still have enough metal for the fit
CARPENTER NOS OBSOLETEPARTS in Concord NC = 800-476-9653.
PARTS INTERNATIONAL in Farmers Branch TX = 888-727-0418.
GREEN SALES CO. in Cincinnati OH = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY = 606-787-5293.
D3TZ-1000396-C.. Absorber (rubber cushion) - Upperradiator support andupperfront and rear cab mounts / Obsolete
PARTS INTERNATIONAL
GREEN SALES CO.
PARTS INTERNATIONAL
GREEN SALES CO.
