1978 - 1996 Big Bronco
Idle Issues
Old Sep 9, 2023 | 06:29 PM
ReanuKeeves125's Avatar
ReanuKeeves125
4th Gear
Idle Issues
My 92 bronco won’t idle correctly, it idles too high. I replaced the o2 sensor and it only made it idle higher. Any ideas / opinions as to why
Old Sep 11, 2023 | 09:20 PM
351Cleveland C4's Avatar
351Cleveland C4
IAC might be stuck. Or else you have a vacuum leak.
Old Sep 12, 2023 | 06:15 PM
ReanuKeeves125
4th Gear
Idle issues
I’ve pulled of the IAC cleaned it, was planning on replacing it anyhow. I’m leaning toward the vacuum leak. When you stomp on the gas when it’s in park, the idle will drop by about a grand and then clime back up. Would that be my choke, and what vacuum lined does affects the choke.
Old Sep 12, 2023 | 06:28 PM
351Cleveland C4
You don't have a choke
Old Sep 12, 2023 | 06:54 PM
ReanuKeeves125
4th Gear
Any idea what vacuum line I’m looking for? And is there a vacuum line diagram in the Haynes book?
Old Sep 13, 2023 | 06:19 AM
rla2005's Avatar
rla2005
There is supposed to be a vacuum routing diagram on the radiator support or attached to the under side of the hood.
Old Sep 13, 2023 | 11:37 AM
ReanuKeeves125
4th Gear
Thank you, I’ll take a look at it when I get off work
nico963
6.7L Power Stroke Diesel
Jun 11, 2021 12:33 PM
B1GKAHUNA
Apr 9, 2014 09:18 AM
tip49
May 12, 2013 08:09 PM
Benny2002
Apr 16, 2007 08:14 PM
