Holley 94 Jets
Old Sep 8, 2023 | 03:22 PM
arthall's Avatar
arthall
Holley 94 Jets
I have a holley 94 carb on a 1953 flathead V8 (239 8BA). I have seen various recommendations for jet size depending on ambient temperature and elevation. My truck will be used exclusively at 1000 feet above sea level with most ambient temperatures between 50F and 90F. I have tried .051 and .052 jets and noticed little difference between the two. I would be interested in recommendations as to the optimum jet size for this truck and conditions.
Old Sep 8, 2023 | 03:48 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
51 is what Ford used for 0 to 5000 ft.
Is there a symptom you are chasing?
Old Sep 8, 2023 | 04:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The power valve has more effect on mileage. Dropping down from the stock 7.5 to 6.5 or even 5.5 is worth trying.
Old Sep 8, 2023 | 05:44 PM
arthall's Avatar
arthall
Thanks for your input. No, not chasing a sympton. Just educating myself on the truck. And I have always enjoyed messing with the carb.
Old Sep 8, 2023 | 05:47 PM
arthall's Avatar
arthall
The power valves that I have don't seem to have any markings as to pressure spec. Shouldn't they have something stamped on them? I am going to try some different ones like you recommend. Thanks for the help.
Old Sep 8, 2023 | 06:05 PM
52 Merc's Avatar
52 Merc
With all the diagnostic gadgets available now, a handheld tailpipe sniffer might be a fun investment for you. It'll let you zero right in on optimizing your tuning by reading what's in your exhaust.
Old Sep 8, 2023 | 06:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If they aren't marked, I'd assume they are 7.5's
I have an Innovate MTX-L O2 exhaust monitor for this very reason. Also since I swapped carbs to the Rochester 2G, I almost had to get one. Plus I have to deal with mile-high altitude. It's amazing what you can learn from them. For instance, on a Holley 94 trimming down the idle jets makes a difference up to around 2,000 RPM. Even with the correct main jets, if the idle screws are set too fat, around town you'll get terrible mileage. At higher speeds, I can see exactly when the PV starts dumping in gas, and the 7.5's come in way too early.
Here's a short video of the AFM in action (actual speed is 62 mph on I-25):
Old Oct 10, 2024 | 01:51 PM
Stude55's Avatar
Stude55
2nd Gear
ALBUQ F-1, Can you tell me what Jets and power valve you are running at 5000 ft ? I am currently setting up a triple 94 carb set up for a Studebaker. I do have an O2 sniffer I will be using but what you are running would at least give me a good starting point?
Old Oct 10, 2024 | 04:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'm not running the Holley carb anymore, but the jets I was using when I had it were #51 (stock) and 6.5 power valve. I tried as low as #49 mains and there was little difference. The power valve makes a bigger difference, and I would go as low as 5.5 with your setup, IF you will be driving at 5,000' and higher.
Setting the idle mixture screws as lean as you can without poor idle quality makes a big difference all the way thru mid-range.
Old Oct 11, 2024 | 12:27 PM
Stude55's Avatar
Stude55
2nd Gear
.Thank you, yes I always adjust mixture screws to lean best idle. Our Altitude is over 5000 ft not to mention density altitude. If you didn't notice a change with #49 mains then I will see what #48 jets and the 5.5 power valve give me. Thank you for your response. I don't think the intake will go on until this winter but I will post the final jet size and power valve used along with the air fuel ratios under cruise and power enrichment and the density altitude at the time.
CJMOStang
Oct 6, 2022 09:27 AM
arthall
Oct 2, 2019 04:23 PM
51phil
Jul 19, 2015 10:10 AM
53OlderThanMe
May 11, 2008 07:08 PM
truckman87
1947 and Older Ford Trucks
Aug 28, 2005 11:45 PM
