7.3 POWERSTROKE ENGINE STALLS
Old Sep 7, 2023 | 10:15 AM
lightmayo94's Avatar
lightmayo94
Trailering
I have a 1999 it has 576k miles on it. It started yesterday when I was picking up my kids from school it was stop and go traffic. The truck stalled out and the engine shut off when I let off the accelerator. Also does the same thing on an incline when I let my foot off the accelerator and if the truck rolls back and push down on the accelerator to go it shuts down. It just started doing this, could it be cause it has so many miles? Or can it be fixed? Has anyone else had this problem.
Old Sep 7, 2023 | 10:34 AM
Kwikkordead's Avatar
Kwikkordead
Lots of different possible causes for this. Most likely, judging from your description of symptoms, in my opinion is the high pressure oil solinoid is sticking. It's mounted off the bottom of the high pressure oil pump which is mounted below the fuel filter housing. Don't trust Amazoo parts. Only Motorcraft for this one.
But please don't take my word for it. The parts cannon can get expensive. Need to do some proper testing to verify.
Old Sep 7, 2023 | 10:35 AM
Kwikkordead
At the top of the forum is a crash course in reading up on how to diagnose and repair these vehicles. Required reading if you want to be proficient at it.
Old Sep 7, 2023 | 11:31 AM
lightmayo94
Trailering
Ok is that the IPR?
Old Sep 7, 2023 | 11:34 AM
Kwikkordead
Originally Posted by lightmayo94
Ok is that the IPR?
Yes. I left the abbreviation out because I didn't know if you were familiar with them or not.
Old Sep 7, 2023 | 12:23 PM
RacinJasonWV's Avatar
RacinJasonWV
It does sound like an IPR. But there are other things to check as well.
Only buy a motorcraft IPR from a trusted source. Amazon/eBay and the like are not considered trusted. Too many fakes. CNCFab, Riffraff, or the dealer would be trusted in my opinion.
How’s the oil level? The injectors work off of oil pressure so low oil can cause running issues. Doesn’t sound like your problem but free to check.
How’s the fuel level? It can start sucking air near 1/4 tank if there’s issues with the in tank pickup.
You could try with the ICP (drivers side head in front) disconnected to just get a reference point. It reads the pressure and the IPR adjusts it. It will run off default tables if ICP disconnected. Again, free to try.
Best option is to get a OBD dongle and FORScan to log some data for ICP.
Old Sep 7, 2023 | 03:10 PM
udsuth78's Avatar
udsuth78
Yep, I'm going tin nut on the IPR. Loose or laying in the valley that's my bet.
Old Sep 7, 2023 | 03:20 PM
lightmayo94
Trailering
the tank has 3/4 of fuel. I will try to see if the IPR is the problem thank you guys.
Old Sep 7, 2023 | 07:35 PM
RacinJasonWV
Oh yes, that’s a likely possibility. I forgot about that one. 🤦‍♂️
Old Sep 8, 2023 | 08:26 AM
lightmayo94
Trailering
Well the nut did back off on the IPR thanks every one for the help.
Old Sep 8, 2023 | 11:51 AM
udsuth78's Avatar
udsuth78
Winner winner chicken dinner!!!
Old Sep 9, 2023 | 01:09 AM
FinnishStroker's Avatar
FinnishStroker
Gongrats for the easy fix!
You beat me with the mileage!
528k here.
Old Sep 9, 2023 | 07:23 AM
Matthew_in_CO's Avatar
Matthew_in_CO
Well the nut did back off and IPR thanks every one for the help.
Good to hear you found the problem.
Have you ever changed out the low pressure/lube oil pump? With so many miles that would be my very next upgrade. I think I would replace every 300k even if you had already replaced. Melling made an updated design that blows the stock pump out of the water, makes everything on the engine perform better. Keep her running!
Old Sep 10, 2023 | 07:28 PM
lightmayo94
Trailering
Will do I was just watching a video about that. It’s in pretty good shape for 576k miles.
Old Apr 1, 2024 | 09:15 PM
Black Buzzard's Avatar
Black Buzzard
wrong thread...
WXboy
Jul 20, 2022 10:24 AM
Kensco123
Nov 1, 2021 05:55 AM
IDI guy
Jan 22, 2012 04:49 PM
bigtexan99
21
Feb 27, 2011 01:11 PM
