I have a 2021 6.7 F350 Super Duty. Truck has around 12500 miles on it. Tuesday I was pulling my Outdoors RV travel Trailer down a steep forest service road after camping a few days. I had the transmission in manual & the engine brake engaged going down the steep road. Two - 3 miles down all of a sudden the dash flashed "reduced engine power" since I was headed down hill I really wasn't using much power. I noticed the engine would hardly rap up. I got to a wide spot & pulled over I thought to myself what am I going to do. I have a 10,000 lb RV on the back. No way would the truck pull it in this mode. I put the transmission in neutral & hardly any throttle response.
So, I shut the truck off ,waited a minute, started it back up. Got down to the main HWY (160) all power back to normal. 35 miles down the HWY not a problem.
Any ideas why this truck did this?
The def tank is over half full. That is the only reason that I can think that it would go to reduced power. Just a hiccup or do I need to investigate this further before I get left stranded.
Well, I know that I did not over rap the motor, not even close. Even in manual it should shift up in case of a over rap. The fuel tank was 3/4 full. The def tank a little over half full. I believe as I was coming down the road I was shifting from 1st, 2nd & 3rd & might have done it a little too quickly back & forth. And confused the transmission. As I stated as soon as I shut the motor off & restarted it. It has been perfect like it has been all along. Went today & topped off the fuel & took it on a 35 mile drive & it behaved perfect. At this point I'm guessing that this is what happened.
Thanks,
Russ
There will be a DTC stored that will indicate what led to the restricted power mode. The chain autoparts stores offer free code reading and their scanners can pick up the DTC.
I wouldn't be alarmed as electrical hiccups are pretty common with the diesels and the old shutdown/restart practice gets you going again. I see it often enough amongst my customers and the next time the truck is in for service I run the history and usually find a coolant or emissions related sensor didn't report back in time and the computer tripped a fault sending it into limp mode.
