1988 LN8000 VIN
I'm giving you your own thread for this truck for clarity and easy reference for any future questions.
1FD P R82 A 5 J V A28644
1FD = Ford Motor Company USA, incomplete vehicle
P = Class 7--26,001 -33,000 lbs GVWR
R82 = LN 800 diesel (badged and referenced as LN8000 elsewhere)
A = 7.8 Ford six inline diesel engine. (Brazilian)
5 = Check digit, ignore.
J = model year 1988
V = Kentucky Truck Plant
A28644 = serial number
9E = Special White
204 = 204 inch wheelbase
R82280 = LN 800 diesel, 28,000 lbs GVWR
A8 = I do not have upholstery info, standard cab
CT = Eaton/Clark model FS -5106 six speed transmission.
2GN
2G = Rockwell model RS-20-145 single speed rear axle, 21,000 lbs capacity, 4.56 ratio
N = Ford 9,000 lb capacity front axle with power steering
87 (???) = Body company. Sometimes seen for rental trucks. IF it's 87.
You should have a while plastic certification label with axle, paint, transmission etc info on it. If you can post a picture of that it can be decoded as well.
EDIT: See post below and edited decode info
J = model year 1988
9E = Special White
2GN
Al-Berta
11-05-2021 08:44 AM
cayceenglar
05-22-2021 10:24 PM
