1988 LN8000 VIN
I'm giving you your own thread for this truck for clarity and easy reference for any future questions.
1FD P R82 A 5 J V A28644 1FD = Ford Motor Company USA, incomplete vehicle P = Class 7--26,001 -33,000 lbs GVWR R82 = LN 800 diesel (badged and referenced as LN8000 elsewhere) A = 7.8 Ford six inline diesel engine. (Brazilian) 5 = Check digit, ignore. J = model year 1988 V = Kentucky Truck Plant A28644 = serial number 9E = Special White 204 = 204 inch wheelbase R82280 = LN 800 diesel, 28,000 lbs GVWR A8 = I do not have upholstery info, standard cab CT = Eaton/Clark model FS -5106 six speed transmission. 2GN 2G = Rockwell model RS-20-145 single speed rear axle, 21,000 lbs capacity, 4.56 ratio N = Ford 9,000 lb capacity front axle with power steering 87 (???) = Body company. Sometimes seen for rental trucks. IF it's 87. You should have a while plastic certification label with axle, paint, transmission etc info on it. If you can post a picture of that it can be decoded as well. EDIT: See post below and edited decode info |
I found the tag, I was looking right at it, Uff, Thanks for your help!
https://cimg6.ibsrv.net/gimg/www.for...93afc96e56.jpg |
Let me know if I missed one or missed a number.
CDL truck..... |
Originally Posted by 85e150
(Post 20967768)
CDL truck..... |
