Probably one of the best gas engines in a real truck today (real as in class 2B or class 3-4) If I didn't want a truck that can turn inside itself like the F-450, I would have looked into a 7.3 DRW. It wont walk up a mountain with ease like the Diesel when towing a 5th wheel, but I rarely climb mountains as it is. Only reason I have the Diesel is it is the only engine that comes in the F-450.
If you can talk me out of a SD for now that would be great! Most all the used SD's I've seen are running about $50K for a truck with 100K + miles. Ouch!!
Haha, that is exactly why I purchased new, used really makes no sense. The issue you'll run into with your 150 is you'll run out of payload before hitting the max towing capacity more than likely, however your payload is pretty high for an F150. Why not find a camper you like, see how your truck does and go from there? You are planning on buying both so just do them in that order instead of truck first then camper. Drive the camper home or where ever then decide if you need to upgrade to SD truck.
How often will you be towing?
Does MPG matter to you much? Do you need to park in small spaces or have a small garage door? My lifetime avg after about 6k miles on my 7.3 is right around 10 MPG, that's probably 60-70% towing our camper and the rest is mainly in town driving. On the highway I probably hit mid teens but anything stop and go get ready for single digits MPG. The turning radius sucks on these and it's not gonna be fun to parallel park or get into tight parking spots.
If we didn't upgrade to a 38 ft 8k wet camper I'd likely still be in my F150 pulling my 28 ft 6k wet Jayco. It pulled that camper like a dream, but I'm also comparing that truck to an 04 F150 with the gutless, yet reliable 4.6.
A 7.3L or a 6.8L gas engine will easily tow your trailer, and more. The reliability debate can be spirited. You'll get passionate responses from both sides.
A gas engine has a lower initial cost. Fuel mileage isn't as good. Fuel is generally cheaper. Repairs tend to be less expensive. Oil changes are more frequent but less expensive.
A Power Stroke is more expensive. Fuel mileage tends to be roughly 30% better in most situations that I have observed. Fuel is generally more expensive. Repairs tend to be more expensive. Oil changes are more expensive (13 quarts) but you don't need to change your oil every 3,000-5,000 miles.
And why does Ford require the sport package when all you want is the XLT Premium package???/ UGH
Money grab. Same reason you can't get the 7.3 in a XL unless you add the $5k STX package. Ford is learning how to squeeze the most money out of someone who just wants a couple features....now they are sucked into $7,000 packages to get those couple features
Was leaning diesel but either will do. Whichever is preferred and most reliable.
Stay away from the diesel if you want reliability.
I should say that technically my F150 will pull the trailer we are looking at. My truck has a payload of 2219 lbs. The trailer is 7000lbs GVWR and has a hitch weight 490 lbs. It's 27' long and 11' height. The Ford towing guide that list all the combinations shows 9200 lbs towing capacity for my truck.
Your F150 may well be able to tow it (though the Super Duty would certainly do a much better job), but the loaded tongue weight will undoubtedly be far more than 490lbs; figure on 12 - 15% of GVWR. My 21RBS (24'10" OAL) had a GVWR of 8,150 and a measured TW of 1,180 lbs.
