Sponsored by: Auxito
Automatic door locks
Old Nov 20, 2003 | 03:05 PM
rcressey's Avatar
rcressey
Angry Automatic door locks
I have a 2003 Ford F150 4x4. The one thing I hate is the automated door locking. Does anybody know how to disable that feature?
Old Nov 20, 2003 | 05:15 PM
triton_2002's Avatar
triton_2002
I don't know the exact procedure, but look in your owners manual. It should be a series of off and on toggles of the ignition switch.
Old Nov 21, 2003 | 01:51 PM
leroys4wd's Avatar
leroys4wd
disable autolock:
The enable/disable mode allows the autolock feature to be turned off and on.
On manual transmission vehicles, when replacing the remote anti-theft personality (RAP) module, the autolock feature must be turned off by using the enable/disable mode. The enable/disable mode is entered when the following series of steps is performed:
1. Confirm that the perimeter alarm is disarmed.
2. Close all doors.
3. Confirm that the ignition switch is in the OFF position.
Note: Steps 4 through 8 must be performed within 30 seconds.
4. Turn the ignition switch from OFF to RUN.
5. Press the power door lock UNLOCK button three times.
6. Turn the ignition switch from RUN to OFF.
7. Press the power door lock UNLOCK button three times.
8. Turn the ignition switch from OFF to RUN.
9. Verify that the RAP module chirps the horn.
This indicates that the RAP module is now in the enable/disable
mode and ready to accept program changes.
10. Press the power door lock UNLOCK button one time to command the RAP module to toggle the autolock/relock feature ON or OFF.
11. Press the power door lock LOCK button once to enter the command.
12. Verify that the vehicle horn chirps one time to signal the RAP module
confirmation of the command. There should only be one chirp indicating
that the autolock/relock feature has been disabled. If one chirp is heard,
followed by a longer honk, the autolock/relock feature has just been enabled.
Return to step 10.
13. Turn the ignition switch to the OFF position to exit the enable/disable mode.
14. Verify that the RAP module chirps the horn once to indicate that
a feature has been changed. The autolock and the appropriate alarm
configuration are turned on at the factory on vehicles with automatic
transmissions. Vehicles with manual transmissions have the autolock
turned off at the factory. The RAP module returns to the prior setting any
time battery power is interrupted.
Old Nov 21, 2003 | 03:35 PM
rcressey's Avatar
rcressey
Thanks, I found the instructions and disabled the locks.
