Where to store propane tank?
I'm trying to figure out where to store/mount a propane tank on the Ex. I use the propane for my blackstone griddle with side burner and for a propane fire pit when camping.
I would like to use a 20 lb tank but could go smaller. Definitely do not want to use the disposable 1 lb tanks.
Any recommendations?
I've considered getting a new bumper with the swing arm, and mount the propane tank on the swing arm. But I'd prefer to not do this, as I don't plan on carrying a spare (running 37" tires and may go to 40's one day). Some of the swing arm bumpers aren't rated for tires that large, and none of the other cars I have owned in the last 15 years have a spare anyways. I also don't care for the look or the added weight of the rear-mounted spare. Another issue is that most of these types of bumpers also do not let you swing the barn doors all the way open.
Now if I could find a swing arm bumper that didn't interfere with the barn doors and would just let me mount propane and water cans, maybe that's an option but a real expensive one.
Also thought of bolting something to the outside of the barn door, but since its fiberglass would have to engineer something that tied it back to the steel on the inside.
The following users liked this post:
yea, definitely not in the cabin, i was coming home from a trip and had a half spent green can in the back, and half way home i started smelling it, and realized it must be leaking, so i stopped, vented the vehicle, and got rid of the can.
I've heard before the cheap green store bought cans do not reseal properly after being used, but first time i experienced it, glad i have a sensitive nose and smelled it before it built up inside too much.
Forgive my ignorance, but what is the purpose of a dual receiver hitch?
Per TorqueLift literature it is for added strength. You can use the upper receiver for a bicycle rack or for some other use. For the Ex, maybe not as good an idea as for a non-barn door configuration.
Duh……to pull 2 trailers!
Having the choice allows for some additional height adjustability for the drawbar, I use the bottom hole for my Hensley Arrow hitch stinger with its 4” drop/rise going up, keeps the big TT level.
The dual receiver concept was born to allow trucks with slide in campers to also tow heavier trailers with a dual beam truss adapter up to about 4’ with side mounted turnbuckle stays.
The hitch is over the top heavy duty and very well made.
I hope someone comes up with a solution on where I can mount that propane tank. I keep staring at the Excursion trying to figure it out. I can get by with a 5 lb tank, which is smaller than the standard bbq grill size 20lb tank. That's about as much as I burn in a trip. Hopefully the smaller size will help solve this problem.
Jasonodsky
I really appreciate you measuring that for me! Thank you. I think this may work for my purposes...trying to maximize the width of some pull out drawers I'm installing in the cargo area.
black water
06-16-2010 12:57 AM
mmmPowerStroke
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-19-2006 09:28 PM
mmmPowerStroke
02-07-2005 07:37 PM
