starting problems
Old Nov 20, 2003 | 01:54 PM
herothc2003's Avatar
herothc2003
starting problems
My engine seems to be flooding or missing when I first start it up only for a few seconds then it levels off and runs perfect.I have used efi cleaners, octane boosts,pretty much everything out there.Any help?
Old Nov 22, 2003 | 01:07 AM
fishnhomey's Avatar
fishnhomey
Do you have dual tanks? If so does the prob. occur more on one tank than the other? Do a fuel pressure check on both tanks-run each one and shut down b-4 testing.I think factory pressure(I have a '96 4.9 efi) is around 25 psi. It will idle until you get below 7 psi. Hope that helps.
Old Nov 23, 2003 | 12:43 PM
herothc2003
nope i have a single tank.
Old Nov 23, 2003 | 08:38 PM
fishnhomey's Avatar
fishnhomey
Is it a high pressure system with an electric fuel pump. I still think thats the problem even without dual tanks. By the way the correct fuel pressure with ignition off is actually(if electric) 50 to 60 pounds in 4.9 efi. good luck
Fastbird
Crossovers
Feb 24, 2015 09:51 AM
jimbomac22
Sep 28, 2010 08:38 AM
whadeen
New Member Introductions
Oct 8, 2008 09:22 PM
mikewalsh1
May 10, 2006 05:29 PM
