Idle adjustment
Old Sep 2, 2023 | 01:34 PM
cullynhaas's Avatar
cullynhaas
4wd Low
Idle adjustment
I have a 1981 ford f100, my idle seems to be running high at 1800 and shifting into first it’s jumpy. How do i adjust it lower and what is the recommended idle speed?
Old Sep 2, 2023 | 02:00 PM
Max Capacity's Avatar
Max Capacity
Have you sprayed the throttle cable with penetrating fluid. It may help.
There should be an adjusting screw on the lever on the carb that moves when you step on the pedal. Adjust that screw.
What engine do you have ? 700rpm or so should be fine.
Old Sep 2, 2023 | 02:31 PM
Franklin2's Avatar
Franklin2
When you first start it cold it should idle fast. If it's a summer day after it runs for a minute or two you should be able to pat the gas pedal swiftly and be able to kick the idle down. If it keeps idling fast, go out and take the aircleaner off and look at the top of the carb throat. There should be a metal door on top of the carb. If the engine is warmed up, this door should be standing straight up. If it's partially or almost shut, that is what is causing your high idle. That is the choke.
With the engine off, push the throttle wide open on the carb and while holding the throttle open, take your finger and open the door straight up and down. While holding the door open, slowly let the throttle back shut. Without touching the gas pedal start the engine. If the engine is warm it should start and idle slow. If you touch the throttle and it suddenly idles high again, go out and look at the top of the carb and see if the door has shut again. If it has, your choke has a problem.
kyle1979ford
Feb 3, 2022 05:57 PM
nico963
6.7L Power Stroke Diesel
Jun 11, 2021 12:33 PM
DAT2109
Apr 4, 2012 09:12 AM
FARM69
Jul 5, 2006 08:59 PM
