Help with running lights.
Old Sep 1, 2023 | 08:28 PM
MyNameIsJeff's Avatar
MyNameIsJeff
3rd Gear
I have a 2017 F350 with a flat bed. Running lights on the cab work but don’t work on the flatbed. If I have my buddy reset the body control module, it works until I hit a bump. Then when I flip the switch it works until I hit another bump, but then eventually it stops working again. I thought it was the flatbed wire harness, but I replaced it and it didn’t work. Then I realized the running lights on my trailer didn’t work with this truck either. Can’t find any exposed wires or reasons for a short. I’ve taken apart all the connections and checked continuity and everything checks out. Any suggestions?
Old Sep 2, 2023 | 12:33 AM
Mirage Flatter's Avatar
Mirage Flatter
Sounds like a poor ground on both the flatbed and the trailer to me.
Old Sep 2, 2023 | 05:48 AM
Just Chilling's Avatar
Just Chilling
You have a bulb shorting out. I have those nickel led’s in my bed and occasionally one shorts out and the whole system goes black.
Just have to start disconnecting them one at a time until the problem goes away.
The first time after I located the faulty bulb I hooked it straight to the battery and it went up in smoke, actually caught fire for a second.
Old Sep 2, 2023 | 08:18 AM
MyNameIsJeff
3rd Gear
That was the first thing I tried. I took off the ground connections cleaned and sanded them and put them back on. I checked them again later. Running lights on both my trailers work with my other truck.
Old Sep 2, 2023 | 08:24 AM
MyNameIsJeff
3rd Gear
Unfortunately, I already tried this too.
Earn88fan
Sep 7, 2021 07:59 AM
johnpitts01
Feb 15, 2020 05:36 PM
Titanrulez
General Automotive Discussion
May 6, 2015 07:33 AM
tooldad1041
Dec 12, 2014 05:40 AM
dhag911
Oct 20, 2006 09:39 PM
