Extremely low Vref and running extremely rich
Old Sep 1, 2023 | 07:07 PM
Wilsalmons's Avatar
Wilsalmons
I’m working on a 1994 f150, 5.0, 5 speed, and speed density, for a buddy of mine. We’re having the trouble of it running extremely rich and in turn very poor. It has new plugs, wire, and cap as well as a new TPS, IAC, and o2 sensor. Tested the Vref in two spots and both were around .34v. So I found and removed the ecu because I’ve heard of the capacitors going bad ans causing problems. (It is a JOY0 ecu). I took off the front and back covers and found all three capacitors were leaking and had gone bad. So I replaced those and I’m still having trouble. The places I tested the reference volts at the orange wire on the tps (at its highest I got .34 volts) and on the egr plug (I don’t remember wire color but had the same reading as the tps wire). At the green wire I can get around .01 v at closed throttle and while opening the throttle the voltage slowly raises to around .32 or so at wide open. Any help is appreciated and much needed.
Old Sep 1, 2023 | 07:33 PM
Hit Man X's Avatar
Hit Man X
Test other things? Sensors and hard parts can also cause a vehicle to run rich.
Old Sep 1, 2023 | 07:46 PM
Wilsalmons's Avatar
Wilsalmons
a lot of the sensors are new and I wouldn’t think a bad sensor would cause the Vref to be so low.
Old Sep 1, 2023 | 07:49 PM
Hit Man X's Avatar
Hit Man X
New does not mean good. BTDT.
Low reference voltage bad too. How is the electrical system on it?
Old Sep 1, 2023 | 07:55 PM
Wilsalmons's Avatar
Wilsalmons
as far as I can tell everything is good. The truck sat a couple years but I haven’t found any evidence of mice. I checked the grounding on a few of the pins of the ecu wire harness and they came out exactly as the what I got on the battery. (Like 12.34 or something. I don’t remember it’s been awhile since I’ve done this). the main wiring harness seems original to me as well as the rest of the wiring. All except the horn. It has been rewired into a button. And the cruise doesn’t work. Would a truck this year have a clock spring and if it went bad would it cause the low vref? I’m not confident it has the original steering wheel either. Which wheel would be on a truck of this year. It has the wheel with the big rectangular middle and two individual buttons for horn.
Old Sep 1, 2023 | 10:18 PM
Briansshop's Avatar
Briansshop
Have you tried checking the Vref with all the sensors unplugged?
Old Sep 2, 2023 | 03:57 AM
My4Fordtrucks's Avatar
My4Fordtrucks
That sounds like the original air bag steering wheel. At least that is what was in my ‘94 Bronco.
Did I miss where you checked for engine off (KOEO) fault codes before replacing all those sensors and after the computer repair?
Old Sep 2, 2023 | 09:30 AM
Wilsalmons's Avatar
Wilsalmons
I did check for codes awhile back and that’s what made me change the sensors, as well as them testing bad. But one of the other codes I do remember getting had something to do with the ecu not receiving enough power. I’ll recheck the codes next chance I get and I’ll give you a little more information.
Old Sep 2, 2023 | 03:07 PM
Wilsalmons's Avatar
Wilsalmons
Ok so I started unplugging sensors and checking Vref on the egr plug with the brown with a white line wire. The first time I did it, it was at .31. I then unplugged the TPs and it raised to .41 and now it’s staying at that with the TPs plugged in. I also found that with the map sensor unplugged I lose all Vref everywhere. Is that normal. I also found that the middle wire on the map sensor only gets around 5.04 volts when testing ground. The battery is at a steady 11.94 volts. Key on engine off. While on my truck (a 1992 flaireside 5.0 5 speed) I get 12.45 volts with a 12.55 volt battery. Where does the map sensors ground to and how can I check it?
Old Sep 2, 2023 | 03:29 PM
Wilsalmons's Avatar
Wilsalmons
I cleaned every ground I could find and it raised the number to 6.84 volts to the middle ground and Vref is still .42 volts to the egr plug and .37 to the TPs
Old Sep 2, 2023 | 03:41 PM
Wilsalmons's Avatar
Wilsalmons
My next question is can I swap a different computer into this truck just to test if it is the computer that’s still bad. For example my truck has the W2M computer and the problem child’s computer is a JOY0. Can these computers be swapped or is their other differences that would cause problems.
Old Sep 2, 2023 | 05:47 PM
OBS4ever's Avatar
OBS4ever
Before swapping the computer. Try cleaning and rebuilding the fuel injectors.⁰⁰⁰ it brought my truck from 7.5 mpg to 15 mpg. It also increased my power and it my engine is running like new.
Old Sep 2, 2023 | 05:50 PM
Wilsalmons's Avatar
Wilsalmons
it probably wouldn’t be a bad idea but it still doesn’t help the Vref issue. Also it runs so rich that it smokes like diesel and you can smell the gas. I’d like to get the electrical part fixed before I worry about anything else. That’s why I wanted to swap a known good computer to see if that was the issue.
Old Sep 2, 2023 | 07:50 PM
Soup bean's Avatar
Soup bean
Is your ECU relay interchangeable with your fuel pump relay? Might be worth swapping them and looking for corrosion in their sockets.
Does your truck have a smaller gauge wire coming off of your battery negative cable? If so, is it grounded well?
How clean are your battery negative connections?
Old Sep 2, 2023 | 08:50 PM
rla2005's Avatar
rla2005
That is not normal. VREF comes out of the PCM Pin 26.
Signal Return is a dedicated ground back to the PCM on Pin 46. Inside the computer Signal Return is tied to the ground path.
