Exessive Oil Consumption
My truck is a 97 F350 with 209k miles. It is consuming more and more oil. The only visible leak is from the CCV doghouse. It drips down the valve cover and runs down by the oil filter housing. It smokes blue for a minute on startup but clears up. The turbo has less than 10k miles on it.
It has always consumed quite a bit of oil. With the CCV straight to the atmosphere I was adding no more than a quart every 1500 miles. I took off the CCV mod and put on a catch can that runs into the intake. During a 2k mile trip to Montana I added a quart every 1000 miles. On a 4k mile trip to Florida I added a quart every 1000 miles. The last 700 miles I added 3 quarts.
On the way to Montana I lost an injector solenoid screw. I had the injector replaced. It was running good after the injector was repaired. On the trip to Florida it started rocking at idle after long trips on the highway. It even stalled once at a drive through. It starts easily and idles pretty good when cold. I think the CPS is starting to go bad hopefully not a big deal, but the oil consumption scares me.
My plan is to swap out the CPS and check the injector o rings. If I don't see anything I am going to do a compression test. If it fails I am shopping for a long block. Hopefully it won't get that far.
Does anyone have a recommendation/ part number for a budget diesel compression tester with a 7.3 adapter?
It has some blow by. But I don't think its bad enough for a rebuild. Here is a link to a video:
https://youtube.com/shorts/uR-kTHf9dmM?feature=share
Check Rosewood Diesel if you decide to rebuild them
As for compression it has some but not too bad, but check compression before dumping any money on injectors
Here's what bad blow by looks like.
https://youtube.com/shorts/CmaU-eX6C...fRswssC_F_IOCt
This was on my 00 f250 with low compression and broken cocked up piston rings. Now I have a rebuild on it.
Turns out I was running the grey CPS that has a recall. Could be causing some problems. I ordered a new one should be here tomorrow.
This thread might turn into an engine rebuild thread. I spoke with Bill at Mountain High Machinist. He sounded like he did good work. He estimated $4k for machining and balancing with no assembly. I hope to get a couple options before I pay 4k for machining and balancing.
Anyone have any suggestions in the Denver area?
The mechanic in Casper ran a contribution test with his scanner. #3 and #8 failed. He saw a CPS code but couldn't tell me when it was from.
I checked for error codes with forescan on my way home from Florida before changing the CPS. No error codes.
Forescan contribution test today passed (after the new CPS).
If you decide on a rebuild, upgrade the valve springs to 910-16 comp cams and install new valves, buy a weldable oil dip stick adapter from CPaddict. And if you haven't already add E fuel, or if you can get your hands on a 99-03 7.3 super duty timing cover and fuel system including engine fuel lines, fittings etc on the cheap do it.
Looks like this is going to turn into an engine rebuild thread.
Lots of local shops use Mountain High Machine. The owner has the reputation for being really meticulous with the machining and balancing. He gave me a ball park estimate of $4000 for the machining and balancing no parts or assembly. Seemed high.
Hy Performance Engines in Tennessee would machine and balance for about $2000. I would need to ship but it might be cheaper in the long run.
Any recommendations for a machinist would be greatly appreciated. I can drive from Cheyenne WY to Pueblo Colorado to drop the parts off.
Compression Test Numbers:
1 320
2 330
3 320
4 290
5 360
6 320
7 290
8 340
But at 290psi, I figure it would still run decent.Balancing is not a fast job, it is very labor intensive. @427 fordman did his and showed that these mills are way out of balance.
Going for the cheapest option is never a choice I like to make unless all options have been exhausted.
Things are very expensive in Denver. From rent to Chinese food. The machinist is TN has a good reputation. He did the work in this rebuild thread:
https://www.powerstroke.org/threads/...1375833/page-2
1 320
2 330
3 320
4 290
5 360
6 320
7 290
8 340
