300 4.9 Oil Type
As for the right WT, per the 86 manual for my truck ford recommends a 10w-40 for temps above 0F
and if they remain consistent below 0F than 5w-30 so my 5w-40 is good year round (does it need said?) it's the first number for cold weather
The issue with adding additives, is if you use too much you can do as much damage as not enough.
I'd rather choose an oil that gets it close than have too much.
Yup. 5 qts + 1qt with filter change —>6qts. We always put 6 qts in trucks when I worked at the Ford dealership in the 90’s
thats a myth. If your gaskets are good they are not going to leak.
don't take my word for it, just search.
The only post I saw that got me thinking was one that suggested the higher detergent in syn might be flushing the sludge sealing gaskets away. I have zero evidence of this, but is an interesting hypothesis. And if true, may be the reason for such wildly differing experiences....especially if the engine was not freshly rebuilt.
The first 8 or ten links I saw were all anecdotal. They ranged from "my 19xx XYZ model leaked 10 minutes after oil change" to "I've run syn in everything for 10 years and not a drop ". I sure would like to see some real testing and results, but I have yet to find any.
The only real testing you're going to see is to try it yourself. How would you test? Take a leaky motor and put synth in it and see if it leaks more? It probably will.
If it isn't leaking, than it most likely won't. Send the request to project farm he might take on the challenge.
He might have actually done this with seals already. I think that test was just if high mileage oil did anything to seals at all.
The following users liked this post:
I too, was hoping this would not turn into one of those... In the end, oil is oil. Just use a decent oil and filter and change them when you should.
quaddriver
02-17-2009 01:20 PM
TallPaul
Oil & Lubrication
04-01-2004 09:17 AM
