Suddenly Not Starting
Old Aug 30, 2023 | 10:23 PM
KK560's Avatar
KK560
My truck all the sudden didn't want to start. It'll crank over but not fire, and no service lights or notifications on the gauge cluster, so I hooked up my scanner and got these codes...
what are these and what should I be looking for?
Old Aug 31, 2023 | 10:45 AM
projectSHO89's Avatar
projectSHO89
You need a new scan tool. Whatever that thing is, it isn't displaying valid fault codes in a Ford-recognized format.
It also helps if you explicitly identify what you are working on.
Old Aug 31, 2023 | 11:05 AM
2jhanna's Avatar
2jhanna
have you had the Fuse27 relocation mod done ?
Old Aug 31, 2023 | 12:00 PM
KK560's Avatar
KK560
Nope. No fuse relocation.
Old Aug 31, 2023 | 12:02 PM
KK560's Avatar
KK560
I'm working on a 2014 F150 5.0
Old Aug 31, 2023 | 12:06 PM
2jhanna's Avatar
2jhanna
There is a known issue with our model trucks where the fuel pump fuse, fuse 27, in the under hood fuse box on top of the radiator, 20amp fuse, will not blow, but the bottom of the fuse and socket contacts will melt.
you need to open the hood, open the fuse box cover and pull f27 and look at the bottom of it and look down on the socket for evidence of burn and melting.
report back
Old Aug 31, 2023 | 12:55 PM
KK560's Avatar
KK560
report back
Thanks! Will do.
Old Aug 31, 2023 | 01:06 PM
2jhanna's Avatar
2jhanna
Ford issued a TSB, technical service bulletin, a few years ago, that includes instructions, wiring, and new fuse, to relocate F27 to another slot with "heavier" load abilities.
the TSB kit cost about $20, and takes about 30 minutes DIY
you can google TSB 15-0137. There are many threads posted here.
https://www.amazon.com/Motorcraft-WT56872-Terminal-Kit/dp/B01KHL14T2/ref=pd_lpo_sccl_3/139-3597189-9728419?pd_rd_w=xtsth&content-id=amzn1.sym.116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_p=116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_r=5HYTYP91NVM9AMGB5TGZ&pd_rd_wg=j77p6&pd_rd_r=75b65080-833f-4d2d-bc12-8f8438bf0c46&pd_rd_i=B01KHL14T2&psc= https://www.amazon.com/Motorcraft-WT56872-Terminal-Kit/dp/B01KHL14T2/ref=pd_lpo_sccl_3/139-3597189-9728419?pd_rd_w=xtsth&content-id=amzn1.sym.116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_p=116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_r=5HYTYP91NVM9AMGB5TGZ&pd_rd_wg=j77p6&pd_rd_r=75b65080-833f-4d2d-bc12-8f8438bf0c46&pd_rd_i=B01KHL14T2&psc=
1 1
if the fuse and socket look good, your problem could be the fuel pump driver module, also a common problem on our trucks, located under frame near fuel tank.
Old Aug 31, 2023 | 08:09 PM
KK560's Avatar
KK560
https://www.amazon.com/Motorcraft-WT56872-Terminal-Kit/dp/B01KHL14T2/ref=pd_lpo_sccl_3/139-3597189-9728419?pd_rd_w=xtsth&content-id=amzn1.sym.116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_p=116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_r=5HYTYP91NVM9AMGB5TGZ&pd_rd_wg =j77p6&pd_rd_r=75b65080-833f-4d2d-bc12-8f8438bf0c46&pd_rd_i=B01KHL14T2&psc=1
I was going to pull it inside with my other truck to check it out and since I had to turn the key on to put it in neutral, I was curious if it'd start this time, and it did. I then drove it in and checked fuse 27 and see it was starting to melt. I looked inside the socket and it looks just as clean as the rest. I'll have to get a new fuse tomorrow to make sure that's the only problem.
Old Aug 31, 2023 | 08:36 PM
2jhanna's Avatar
2jhanna
Understand that putting a new fuse in is only a bandaid.
you should do the TSB, fuse relocation as posted above.
this can fail at any time, even going down the road at 60mph, you end up with a dead truck.
Old Aug 31, 2023 | 10:36 PM
KK560's Avatar
KK560
I have one ordered. It's supposed to be in tomorrow afternoon.
Old Sep 2, 2023 | 06:34 PM
2jhanna's Avatar
2jhanna
Did you get the kit installed
Old Sep 6, 2023 | 02:36 PM
KK560's Avatar
KK560
Yep, and put on 300 miles without any problems.
3twinridges
36
Mar 16, 2023 06:27 AM
RailDawg
2021+ F150
Jan 3, 2023 12:48 PM
Grannygear
Dec 20, 2019 11:13 PM
the gruffalo
Apr 15, 2017 01:56 PM
