Quick question- Bedside shape
Old Aug 26, 2023 | 06:13 PM
strangewoods's Avatar
strangewoods
quick question. Kind of a dumb one but I think if I get the answer I can clear my mind. Thank you in advance. I appreciate how helpful everyone is here.
My 85 had some pretty excessive filler on the bedsides. Like both sides had been dented in pretty severely. Slight amount of rust bubbling through around the wheel arch’s.
I removed all the filler and welded in new wheel arch’s. Now I’ve applied some filler but I’m a bit unsure of the contour of these panels and no truck to go look at right now and see. It’s not from top of bed to bottom I’m struggling with. It’s more the “length”
does the box side run straight from front to back or does it begin to taper inward toward the rear? When I put a long straight edge on either side it sure appears that it tapers, starting just behind the wheel arch or so. I only have a 4’ straight edge so I can only check so far.
Maybe it’s a subtle thing I never noticed.
or perhaps I have a lot of dinking around to do to get the Boxside to be flush to a straight edge the whole length of the box..
not going to be a show truck but I want it to look good.
Old Aug 27, 2023 | 12:20 AM
BigBlue2's Avatar
BigBlue2
Seems that right at the pinstripe or the chrome strip bump out it stays pretty straight till right at the corner. I haven't thrown a straight edge on mine yet but google some images and it looks straight.
These guys probably have an answer for you
https://www.classicindustries.com/sh...els/truck-bed/
Old Aug 27, 2023 | 01:57 PM
Max Capacity's Avatar
Max Capacity
I'm thinking the side are straight from front to back. Let me know if you need more or better pictures.
Old Aug 27, 2023 | 03:35 PM
Max Capacity
I did go out and measure the distance from the top, inside rail, on the bed, its 65" wide front and rear.
Old Aug 27, 2023 | 03:46 PM
BigBlue2's Avatar
BigBlue2
I slapped a 60 inch straight edge on mine. I'm seeing a slight flair out from a front corner to the front of the wheel well, about 34 inches. Then it's pretty straight from there aft.
Old Aug 27, 2023 | 04:10 PM
strangewoods
Thanks for looking guys.
I’m not sure what happened to this box in the past. Reckon maybe some feller had a few too many road sodas and slid her sideways into a tree, on both sides… haha
I’m not gonna put the time in to make it perfect but I also don’t think it’ll be noticed by many if this is a little off from factory.
havetwo
2009 - 2014 F150
29
Jul 20, 2009 12:55 PM
WAR EAGLE!!
Nov 19, 2008 01:49 AM
HYDAFL
2004 - 2008 F150
Aug 4, 2008 01:18 AM
gf350
Mar 17, 2007 01:06 AM
