Will it fit?
Old Aug 23, 2023 | 01:25 PM
ynot321AB's Avatar
ynot321AB
Will it fit?
Looking for a flathead motor for my 1950 F-1 1/2 ton. Found a 255 ci, 110 hp motor out of a 1 1/2 ton truck. Will it fit into the 1/2 ton and will the transmission from the 239 fit it?
Old Aug 23, 2023 | 01:35 PM
52 Merc's Avatar
52 Merc
The 255 is the Mercury version of the Ford 239 Flathead. The heads should have 8CM or EAC on them, and may have Mercury cast on them, as well. The engines are physically identical and should drop into your truck, especially if it was already in one, 48-52. 53 would have different mounts. Since both engines use the same block, understand someone could put Merc heads on a Ford stroke engine and pretend it is something it's not. The 255 was never used in a truck in US production.
Old Aug 23, 2023 | 01:41 PM
ynot321AB's Avatar
ynot321AB
If the 255 was never used in a truck in US production, evidently someone is try to pull one over on me as he stated it is in a 1 1/2 ton truck. The pic you sent of the head matches the 24 bolt heads off of the 239 that I have. I have parts from the 239 but the block that I got was cracked so I presume that some of the parts might be interchangeable.
Old Aug 23, 2023 | 01:56 PM
gogoat's Avatar
gogoat
Where are you located? I have a flathead V8 from a 49F1. In NW Iowa
Old Aug 23, 2023 | 02:17 PM
ynot321AB's Avatar
ynot321AB
What might you be asking for your 255? I am in West Central Arkansas. I was born and raised in NW Iowa, a little town Called George. Also would the trannie from the 239 fit the 255
Old Aug 23, 2023 | 02:18 PM
52 Merc's Avatar
52 Merc
It's possible someone transplanted a Merc engine into the truck at some point. It's entirely possible he's telling the truth. The intent of my message was to give you enough information to verify what he's telling you. Keep us posted on what you find. Good luck in your quest.
Old Aug 23, 2023 | 02:20 PM
ynot321AB's Avatar
ynot321AB
Thank you for your help and info and will advise
Old Aug 23, 2023 | 02:39 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
The 255 is a 239 block that has been fitted with a crank allowing for deeper stroke (4") and different heads to achieve the higher displacement. https://en.wikipedia.org/wiki/Ford_f..._V8_engine#255
A true Mercury 255 is valuable, especially for the 4" crank. However, over the years, it is quite possible that simply the heads have been changed to Mercury heads and mislead the identification. One should pull a plug head and bar the engine over to measure the stroke becoming sure of what they are getting. (A 255 will have 4" and a 239 will have 3.75")
It should drop straight in place of your 239, but won't be factory correct. No Ford Truck had a 255 from the factory. It was mainly the Mercury Cars that could have a 255. https://www.ford-trucks.com/forums/6...-flathead.html
Edit: I must type slow - others have chimed in.
As for transmission fit, that has more to do with the validity of the combo ation of engine, bell housing, transmission, frame rather than just the engine ad tranny itself.
Last edited by bmoran4; Aug 23, 2023 at 08:33 PM. Reason: Thinking one word and typing another!
Old Aug 23, 2023 | 03:33 PM
ynot321AB's Avatar
ynot321AB
Did you get my reply asking your price ?
Old Aug 23, 2023 | 08:10 PM
mtflat's Avatar
mtflat
Short answer: yes and yes. Same physical dimensions and transmission will swap from the 239 to the 255.
I run a 255 Merc in my 48 pickup - I found it in a 1946 1 1/2 ton in Kansas. It does happen.
By the way, you can't pull a plug and measure the stroke. The plugs sit over the valves, not the piston. You have to pull a head or remove the oil pan to determine is it has a 4" crank.
Old Aug 23, 2023 | 08:17 PM
bmoran4's Avatar
bmoran4
I meant head but somehow typed plug!
Old Aug 23, 2023 | 08:20 PM
mtflat's Avatar
mtflat
I can't count the times I've done that. I did think about letting him try...
Old Aug 24, 2023 | 06:41 AM
ynot321AB's Avatar
ynot321AB
Thanks for the information
Curated Content Editor
Large Truck
Jan 23, 2020 12:59 PM
KTM1217
Jul 9, 2012 06:33 PM
arrowheadfred
Jul 12, 2011 12:22 AM
Fordication
Jun 19, 2004 09:27 PM
RichAndCyndi
Aug 12, 2003 03:46 AM
