Windshield Washer Fluid Sprays Randomly???
Old Aug 23, 2023 | 07:04 AM
Chingon's Avatar
Chingon
Question Windshield Washer Fluid Sprays Randomly???
2021 F350 King Ranch 6.7L CCLB 30k miles
I noticed that my passenger side washer jet will squirt a bit of fluid randomnly, usually a few minutes after activating the washers manually. Also did it while parked and off. Probably happening more because the reservoir is emptying out really fast.
Anyone heard of this or do I have a haunted F350?
Old Aug 23, 2023 | 08:36 AM
obiwan kenobi's Avatar
obiwan kenobi
You can pull the nozzle hoses off and check flow, they sometimes clog up, some have had success using a small paper clip to clear the blockage.
I replaced my nozzles and still had spray pattern issues, ended up draining the washer fluid tank where I discovered liquefied matter which blocked the pump.
Old Aug 23, 2023 | 10:27 AM
6.2caribou's Avatar
6.2caribou
Maybe a few Kegel procedures would be beneficial...
Old Aug 23, 2023 | 03:20 PM
Chingon's Avatar
Chingon
To be clear I’m not talking about the spray pattern. The fan spray pattern is fine.
The passenger side wiper fluid nozzle is just squirting short bursts by itself, with no activation of the wipers/drivers side fluid.
doczenith1
6.7L Power Stroke Diesel
Sep 14, 2021 01:34 PM
phoneman91
Feb 21, 2009 06:07 AM
TchTchr
Feb 22, 2008 05:05 PM
saipan
General Automotive Discussion
Jul 31, 2005 06:37 PM
labenske
Feb 24, 2005 09:40 AM
