Sponsored by: Real Truck
Trailer brakes not working
Old Aug 22, 2023 | 06:52 PM
mystang891's Avatar
mystang891
5th Gear
I have a 2013 f350 6.7, just bought it. I've been hauling trailers for a while with my other truck but decided to start with this one. I noticed the truck felt like it was getting pushed around when stopping so I used the factory trailer brake adjuster on the dash to see if the trailer brakes were engaging. I got a "trailer disconnected" message even though the trailer was there... Connected.... Right behind me... And all the lights worked. I got out and checked the fuses in the passenger compartment and under the hood. Both are fine.
What do I need to look at next? The trailer brakes work on the other truck.
I'll clean the connectors but I really don't think that's it.
Also, I put a new drop down receiver and hitch on it. Could it not be connecting? The hitch isn't painted or anything.
Old Aug 23, 2023 | 04:49 AM
jarayzener's Avatar
jarayzener
Trailering
I've heard rumors that there are wire color differences between an 7-pin RV style plug and a 7-pin utility style plug; maybe the controller can't sense the trailer because a wire is out of place or something.
https://www.etrailer.com/question-292655.html
Old Aug 23, 2023 | 05:34 AM
user 195474726373's Avatar
user 195474726373
When all lights are on do they stay on when trailer brake is applied? If they go out it's a bad ground. Just something to check.
Old Aug 23, 2023 | 06:23 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Is this a utility trailer or is it wired like an RV? Sometimes they aren't wired the same. It's also possible that you just aren't getting a good enough ground. My flatbed trailer used to work flawlessly, then some neighborhood kids played on it and broke one of the light housings. Now I can't get that side to work with most vehicles because the ground isn't good enough, though for some reason it worked fine with the wife's old F150? I still don't quite understand that. I've redone most of the wiring, and have a new set of lights ready for it...if it would just stop raining long enough for me to do the work that would be great.
Old Aug 23, 2023 | 06:49 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
It's probably just some dirt in the plug. Go to Walmart and buy a small bottle of 75% alcohol that has the flip top and flush out the plug, also use a small brush to clean the contacts and flush it again. Let it dry or blow it out with air, it wouldn't hurt to do the same thing to your cord end.
Denny
Old Aug 23, 2023 | 11:03 AM
mystang891's Avatar
mystang891
5th Gear
There's are utility tools trailers I'm hauling.
Also, I checked and the lights do stay on when brakes are applied.
Old Aug 23, 2023 | 12:49 PM
5851a's Avatar
5851a
There is a plug on the back side of the factory 7 pin connector. All 7 pin plugs are to be wired the same way, there is a ground wire from the truck in the 7 pin connector. The trailer is not dependent on the hitch for ground contact.
Old Aug 23, 2023 | 05:55 PM
mystang891's Avatar
mystang891
5th Gear
Well, I was wrong. Sometime between this truck and my other truck the trailers decided they didn't want to play well. It's not the truck. I tried yet another trailer and it's brakes worked fine. Looks like I have trailers which need brake work. Thanks for trying to help everyone.
Old Aug 24, 2023 | 06:30 AM
99powerstrokedF250
Trailer brakes are NOTORIOUS for having issues - my dad had a fifth wheel decades ago that he had to have the brakes rewired MULTIPLE times in the span of a few years because the wires kept breaking/pulling out of the connectors. He finally rewired them himself, upsized the wiring/connectors and wrapped EVERYTHING in a couple layers of electrical tape, and didn't have a problem again. I was just a kid, but I remember helping him do it - we spent a good part of a Saturday doing it.
Basically on most trailers the brake wires aren't really all that protected, so any little thing getting under there (including a rodent) could cause an issue.
Good luck getting it fixed!
Old Aug 24, 2023 | 11:39 AM
WE3ZS's Avatar
WE3ZS
Start by ensuring the trailers ground wire is properly fastened, every electric trailer brake issue that I’ve had was due to a poor ground connection.
wfa0002
All Things Towing
Sep 23, 2023 03:48 PM
kopy kat
All Things Towing
Sep 29, 2021 12:04 PM
Good listener
Sep 5, 2018 04:01 PM
Jansarchie
All Things Towing
17
Oct 7, 2016 03:43 PM
Eastland
Sep 10, 2012 09:01 PM
