De-sulfate the catalytic converters?
My check engine light came on in July, the day after my scheduled 5,000 mile oil change at the dealership. I took it back to the dealership and they said my #2 catalytic converter had failed. A new one was ordered and replaced the second week of August. The very next morning, while driving to work, my check engine light came on again. I immediately took it back to the dealership, and they said the #1 catalytic converter had failed, so a new one was ordered. My truck goes in Tuesday morning for that one to be replaced. I asked the service writer why these cats are failing, and he said they are seeing it a lot lately just past the 50,000 mile mark. I’m just glad the truck is still under the emissions warranty.
The statement of 'seeing a lot lately' is just from that one source and PR to your question.
CAT contamination only comes from three sources. Burning excess oil, coolant ,or poor fuel quality or a combination of any of the three over time.
A forth, from a misfire failure causing raw fuel to burn in the Cat/s and results in excessive temperatures in the Cat.
Anytime a CAT is replaced, there should be a check in mode 6 data for misfire counts per cylinder, to be sure. This history record does not set codes.
A service writer 'opinion or statement' if often useless.
Your lucky the replacement CATS where available. Everyone else has to wait a long time due the the high failure rates and long production time.
Next time you will be paying for it and may wait a lengthy time.
The CAT codes are P 0420 and 430. Look up the description of these to see why.
Just offering you some deeper in-sight on the problem.
Good luck.
The following users liked this post:
The statement of 'seeing a lot lately' is just from that one source and <acronym title="Page Ranking">PR</acronym> to your question.
Good luck.
Good luck.
I definitely won’t be paying for it next time because I will have a new truck by the time they fail again.
JRD761
1999 to 2016 Super Duty
04-24-2021 10:42 PM
