02 randomly looses power
Old Aug 21, 2023 | 05:47 PM
helifixer's Avatar
helifixer
codes were cleared about 200 miles ago these are current
p1211 p1670 p1209 p0603 p1282 p1212 p1247 p0470
last time I drove it it drove fine, After changing injector o rings. owner takes it back, gets about 50 miles away and it will barley climb a 5% grade that is about 1/4 mile long. this is 1/2 mile past 2 miles of 5% grade that it did fine on.
so far he has put a new motorcraft ICP sensor and fuel pump on it.
new alliant injector o rings, fresh fuel filter and oil change.
290,000 miles, unknown if injectors or hpop has ever been changed.
cold takes about 6 seconds of cranking to start
I only got a few days off this time and didn't get to do any troubleshooting. I go back out of town for 14 days Wednesday.
Old Aug 21, 2023 | 05:51 PM
z31freakify's Avatar
z31freakify
Maybe partially blocked in tank filters?
Old Aug 21, 2023 | 10:41 PM
udsuth78's Avatar
udsuth78
Yeah the usual suspects, fuel pressure and injection pressure.
Old Aug 22, 2023 | 03:32 PM
helifixer's Avatar
helifixer
got to drive it today,
after getting up to temp, at 1875 rpm ICP was 687 psi 64.84% duty cycle made it down shift. 2200 rpm 595 ICP psi 64.84% duty cycle and no able to accelerate much
both times when I would let up the accelerator icp would go up to over 3,000 lbs and duty cycle would drop to 4.69%
This makes me believe that the hpop is still good since pressure goes up when demand is removed.
changed the IPR since I have a spare and no change.
still 6 to 7 seconds to build enough pressure to fire the injectors when starting, long enough to set a P1211, P1282 and P1209
could the injectors be leaking enough internally to keep the hpop from building enough pressure?
Old Aug 22, 2023 | 03:39 PM
uglypitbull's Avatar
uglypitbull
Is your LPOP pushing up enough oil to fill the reservoir?
Old Aug 22, 2023 | 03:42 PM
helifixer's Avatar
helifixer
I pulled the top plug when I changed the ipr and the resivor was full, of course I had just run the truck. but it started this morning cold with the same 6 to 7 seconds of cranking after sitting several days
Old Aug 22, 2023 | 04:04 PM
BWST's Avatar
BWST
Got Data?
Does it run better with the ICP unplugged? I understand there is a new one on there, but wanting to eliminate it and the wiring to it as a possible cause, in case the ICP sensor is a fake. Were both the ICP and IPR purchased from a reputable source?
Agree with you - it's hitting 3K psi ICP when let off - sounds like the HPOP is working and no HPO leaks. That IPR% of 4.69% is unusual - I have seen that with fake IPRs. It would be helpful to see a FORScan CSV file of a log when this occurs.
Old Aug 22, 2023 | 04:15 PM
udsuth78's Avatar
udsuth78
Might check that IPR is receiving the correct voltage, maybe even a voltage drop test. Seems like an unlikely cause but I do like to cover all bases. As for the injectors a Cody test or better yet if you've got a hydraulic hand pump you could put a more real world pressure to them. Also don't forget those high pressure oil rail drain plugs under the VC's front and rear. If one of those o rings blew you'd definitely have problems maintaining any pressure.
uglypitbull
1211 could be the HPOP, IPR, PCM, low fuel pressure, injector O-rings, or low reservoir oil (which is why I asked that question). I am sure I might have missed a few
1212 adds the IPR into the mix.....very similar symptoms to what you are describing as well
1670 is more electrical...have you checked the 40 pin connecter wiring for chaffing?
0470 is exhaust pressure....my buddy had same symptoms pulling a trailer.....CEL and that code. His backpressure tube was plugged up/sensor too....
Old Aug 22, 2023 | 04:16 PM
helifixer's Avatar
helifixer
ICP was purchased at the local ford dealer about 2 months ago.
IPR was one of my spares from when I changed a HPOP and installed a new IPR
I stopped once while driving it and unplugged the IPC and it ran worse so i plugged it back in.
the 4.69% was costing
Old Aug 22, 2023 | 04:20 PM
helifixer's Avatar
helifixer
no external oil leaks, I put alliante o rings on all the injectors last month, no change
haven't checked reference voltage.
Old Aug 22, 2023 | 04:24 PM
helifixer's Avatar
helifixer
cleaned and checked the 42 pin connector and harness, this harness doesn't touch the valve cover! checked the entire harness no damage.
EBP and MAP monitored with autoengunity before starting and while driving, within 2 psi before starting and showed normal when running.
Old Aug 22, 2023 | 04:32 PM
Kwikkordead's Avatar
Kwikkordead
All those random codes looks to me like a loose connection somewhere. What makes me believe that is the P1670 which is a communication issue between PCM and IDM. Engine braided ground cable still connected at the valve cover perhaps? Big connector under the air intake fully seated? Valve cover plugs fully seated? 50 cent mod all ok?
Old Aug 23, 2023 | 01:50 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
65% is max commanded output for the IPR, but the resulting ICP does not track. Since the IPR is fresh I'd think either the ICP is bad or the HPO is just blowing past the o rings.
Disconnect the ICP and see if anything changes, PCM will use a default value for fueling so it will kinda almost run normal.
How does the fuel filter look?
Old Aug 23, 2023 | 08:04 AM
helifixer's Avatar
helifixer
ran worse with icp unplugged,
fuel filter and fuel pump changed within the last 200 miles
