IAC Price
Old Nov 20, 2003 | 08:55 AM
tapenick's Avatar
tapenick
IAC Price
What prices have you guys seen for an IAC?
AZ would have to order it and I think it was around $40.
Our 97 wouldn't start without pushing the accelerator again this week, second time that's happened. Thinking there may be a bad spot on the IAC actuator. Weird though, only does it when it's raining.
Let me know on the prices,
Tom
Old Nov 20, 2003 | 11:53 AM
BigMattXXL's Avatar
BigMattXXL
ONe.....MiLlIon.... DoLLaRs... MwuHahahaHa...MwuhAhAHAHaHa!!!
Seems the going rate in Maryland is about +/-$65
XXL
Old Nov 20, 2003 | 07:51 PM
tapenick's Avatar
tapenick
A buddy had another idea - maybe it's the TPS. That might make more sense... seems it could be impacted by damp weather more.
The theory is that it's not registering that there's no throttle.
Thoughts?
Old Nov 20, 2003 | 08:03 PM
BigMattXXL's Avatar
BigMattXXL
I can tell you that the IAC fails usually when it's damp out - hell, the day mine finally bit the dust, it was raining and I had to get to class
If you have more than 50,000 miles on your rig, you might as well change it because it seems that it's a part designed for failure. The new one actually looks different - I think Ford realized the design was crap and improved it.
For $40, I'd go ahead and do it.
XXL
Old Nov 20, 2003 | 08:08 PM
emtabmm's Avatar
emtabmm
All the originals iac's will stick when the first cold snap hits...
And you are right BigMatt, they are updated....
Old Nov 20, 2003 | 08:09 PM
emtabmm's Avatar
emtabmm
Ford dealer price installed = $189-$225 depending....
Old Nov 20, 2003 | 08:21 PM
tsdrallyer's Avatar
tsdrallyer
Not all orginals.... I still hae the original in my '97. It's seen a lot of rain, creek beds, fog, snow and 12 degree temps. It's never been anything but totally reliable.
Old Nov 20, 2003 | 08:23 PM
emtabmm's Avatar
emtabmm
Unhappy "All Originals"
Ok, maybe not all.......
Old Nov 20, 2003 | 09:15 PM
BigMattXXL's Avatar
BigMattXXL
That's funny too, TSD - have you noticed how either it fails in the first 50,000 miles or so or it never gives you any trouble?
Go figure.
And charging $140 in labor to remove 2 bolts is criminal, IMO.
XXL
Old Nov 20, 2003 | 10:10 PM
MisterCMK's Avatar
MisterCMK
If you can get $140 for two bolts, run with it. Not a bad deal if you can get it.
Old Nov 20, 2003 | 10:38 PM
BigMattXXL's Avatar
BigMattXXL
Are you serious?
Charging $140 for this job is like charging $200 for a tire rotation. Same amount of effort and difficulty.
I hate dealerships...
XXL
Old Nov 21, 2003 | 08:48 AM
tapenick's Avatar
tapenick
The closest thing I could find on fordpartsonline.com was a "IDLE SPEED CONTROL". Probably it huh?
Their prices are $57 for the 5.4 and $99 for the 4.6. Thought that was interesting...
Tom
Old Nov 21, 2003 | 08:50 AM
emtabmm's Avatar
emtabmm
Thats it...
Old Nov 22, 2003 | 11:53 AM
Iceman8984's Avatar
Iceman8984
The famous IAC.....................
Mine finally bit the dust a month or so ago. I stopped by the dealership to seek advice from a "service advisor" I did not ask for a free diagnosis but just what was the most popular part replaced when the trucks won't start. He told me that I really needed to get the truck in and soon, because it could be any number of things. He said it may be one or more of the four oxygen sensors, EGR valve or maybe the TPS. He advised that they replace these things all the time usually around $180 bucks.
Most of the time the truck would do it on initial start up (cold), but by the time the engine would get a little heat into, it would act normal. It eventually got bad enough that I was able to get it to my shop and remove the valve while it was malfuntioning. I found the shaft inside of the IAC covered with carbon and stuck closed. Took some carb cleaner ($2.00) and a pick (free), cleaned shaft. Problem solved (priceless). The old gasket usually doesn't tear.
Old Nov 24, 2003 | 03:45 PM
Volman's Avatar
Volman
When the IAC on my '98 4x4 Expy went out, I took it off and sprayed it with brake parts cleaner and worked it around, ran a pipe cleaner around inside, let it dry for a half hour, put it back on, no problems ever since, about a year ago.
Tom Norton
Mar 11, 2011 01:31 AM
earlybirds
Sep 19, 2007 06:34 PM
1990Fordf150v8
Oct 30, 2003 02:56 PM
biznis_3
1983 - 2012 Ranger & B-Series
Sep 1, 2003 05:42 PM
tapenick
1978 - 1996 Big Bronco
Feb 26, 2002 07:18 PM
