1978 - 1996 Big Bronco
high idle
Old Feb 25, 2002 | 08:04 PM
tapenick's Avatar
tapenick
Post high idle
My truck was idling at about 1200 rpms so I cleaned the throttle body and IAC. That made it better for a few minutes but then it got worse... moving up to the 1500-1600 range.
I replaced the IAC - no change.
So I pulled the connector off the IAC - no change.
That makes me think it's the TPS telling the EEC that the throttle is
partially on. That would increase fuel but how is the engine getting the required air... IAC? Why would the IAC open if the TPS is telling the EEC we're not at idle?
Another possibility is a bad intake gasket... anyone know if any of my
symptoms disqualify that?
Thanks in advance,
Tom
Old Feb 26, 2002 | 07:48 AM
FS88Bronco's Avatar
FS88Bronco
Post high idle
Tom, I recently had a high idle problem with my '88 Bronco 5.8L. Engine would start at about 1300 rpm and gradually climb as high as 2200. Cleaned the IAC chamber and throttle body, did not help problem. Someone on this board recommended replacing the TPS. Took his advice ... cost was $23.99 at Auto Zone. Installing the new TPS corrected my high idle problem immediately. John
Old Feb 26, 2002 | 07:14 PM
Flash's Avatar
Flash
high idle
Tom,
If you cleaned the throttle body still on the engine, that will screw up the intake gasket. The fact that the idle was normal or lower when you first started it and then it went higher would make the odds lean toward the intake gasket.
Old Feb 26, 2002 | 07:18 PM
RSCHAP1's Avatar
RSCHAP1
high idle
Tony Bagnall
Mar 18, 2013 08:05 PM
Jlckb5
Nov 7, 2011 07:50 AM
DJdemon6696
Apr 16, 2007 08:30 PM
jcstratt
1997 - 2003 F150
Jan 31, 2006 11:28 PM
irishman200232
Jan 20, 2004 11:04 AM
