Not charging
Old Aug 22, 2023 | 05:24 PM
Hit Man X's Avatar
Hit Man X
Last I bought I THINK was a new 'Pure Energy' brand from Cockauto. That went on my 4.9. Tossed that 70A 2G in trash.
I only has a few hours of idle time and about 2mi of driving. Seems fine.
Old Aug 23, 2023 | 12:49 AM
solanum's Avatar
solanum
Most of the 2g alternators I've owned, and more than 50% of the ones I get called to work on, have fried their output wiring harness at least once. My F-150 is like the truck of Theseus, with everything from the engine to the driver seats to the fuel tanks either new or from a different truck- around 300,000 on the chassis that I know of- yet, it still has the original 2G alternator and the wiring for it, and it all works perfectly.
My experience with the 2g alternators has been that if the output harness is in good shape, it will tend to stay that way, and if not, when replaced with PROPERLY installed replacements, they actually hold up OK- and of course, are cheaper and easier to find than some oddball 3g alternator for a different application. Properly securing the wire to the alternator bracket goes a long way, as does keeping the engine mounts in good shape- most of the problems seem to stem from fatigue that results when the engine moves and the other end of the wire doesn't.
Old Aug 29, 2023 | 06:15 PM
Anonymous12's Avatar
Anonymous12
I’m having a hard time finding just one 1/4” 4 gauge lug. And can’t find a 3/16” 4 gauge lug. The 1/4” is for the solenoid and the 3/16” for the alternator. And I don’t know what size id need for the mega fuse.
https://www.autozone.com/electrical-...use/288532_0_0
this is the fuse. I’ll have to probably buy the fuse before I can figure out what size the lugs need to be but figured I’d ask anyway maybe someone would know. Would I be better off finding the 1/4” lug and the 3/16” lug at the parts store? Whenever I google the 3/16 it shows 3/8 or 5/16 ones and that seems to be what all of them are.
I’m trying to find them individually for like $3 but I can’t seem to find them like that. If I have to buy 3 sizes and get 3 kits it would end up being like $30 for 30 different lugs when I only need 4.
Where should I mount the fuse?
edit:
found this for the 1/4
https://www.autozone.com/batteries-starting-and-charging/battery-cable-and-lug/p/schumacher-1-4in-cable-lug/1042011_0_0?cmpid=LIA:US:EN:AD:NL:1000000:BAC:1948 8533492&&CATARGETID=120054150001289256&CADevice=m& gclid=EAIaIQobChMIp7nxm4ODgQMVUCuzAB0GtgZfEAQYBSAB EgLD7_D_BwE&gclsrc=aw.ds
Old Aug 29, 2023 | 10:15 PM
Hit Man X's Avatar
Hit Man X
Glad you found the lug. Are you doing the 130A or the slightly smaller 90ish guy?
Old Aug 29, 2023 | 10:54 PM
Anonymous12
It’s a 130a. Gonna go by AutoZone tomorrow get the lugs ordered, the fuse and have them look for the other lug or a size down so I can just drill it to the 3/16.
Old Aug 30, 2023 | 03:09 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by solanum
…around 300,000 on the chassis that I know of- yet, it still has the original 2G alternator and the wiring for it, and it all works perfectly.
My experience with the 2g alternators has been that if the output harness is in good shape, it will tend to stay that way, and if not, when replaced with PROPERLY installed replacements, they actually hold up OK- and of course, are cheaper and easier to find than some oddball 3g alternator for a different application….
I couldn’t agree more. I ran the 2G alternator in my ‘87 Bronco 20 years and almost 300K miles. I just swapped the 2G for a 3G in the pickup only because it came with the 351W
To the OP:
If you haven’t already, do a search for Ford 2G to 3G swap. Select garysgaragemahal.com and start reading. It tells you all about the different models of 3G alternators and the models to get one from. Not only that but how to wire it up.
Old Aug 30, 2023 | 03:39 PM
Anonymous12
I’ll Google that. I’ve figured out what I need so far but I’ll double check with that site.
I’m gonna order 4 gauge wire, I have a 200 amp fuse. A 3G 130amp alternator. I can order the 5/16” lug seen a million of them.
The problem I have now:
Autozone won’t get the one I found for the 1/4” in a reasonable time.
I want to be changing this alternator and have it in this weekend, but I can’t find a 3/16” lug for 4 gauge wire from Amazon or any store near me. The 1/4” I can find but it’s expensive for what it is I think I’ll have to bite the bullet on the price there. But the 3/16” is obsolete I guess. I can’t find it. The one I did was a random site I’ve never heard of, which I’m not getting scammed so I didn’t try it. Makes no sense being the alternators stud needs a 3/16”, and it’s mass produced.
It’s 1/4” for the starter solenoid
516” for the fuse. Which I can find easily so 5/16 isn’t an issue.
Old Aug 30, 2023 | 03:42 PM
Island Time's Avatar
Island Time
You need a #10 terminal which is readily available. Below 1/4" terminals go a number system. Here's a link that might help you. https://www.stayonline.com/product-r...-hole-size.asp
Old Aug 30, 2023 | 04:58 PM
Hit Man X's Avatar
Hit Man X
Do you have a welding supply shop locally? They may have that stuff in stock.
Old Aug 30, 2023 | 06:23 PM
Anonymous12
I’ll check
I tried electrical stores, auto parts, and hardware stores so I’ll call around tomorrow for welding shops.
Old Aug 30, 2023 | 07:48 PM
My4Fordtrucks
For my conversion, I got the wire harness from the junkyard. Because the connector was different between my ‘89 and the ‘90 something harness all I had to do was splice my red/light green wire into the 3G harness.
Old Aug 31, 2023 | 01:24 PM
Island Time
I’ll check
Do you have a marine store near you? If not, here's what I believe you are looking for https://www.fisheriessupply.com/anco...4-gauge/230253
Old Aug 31, 2023 | 02:18 PM
  #28
Hit Man X's Avatar
Hit Man X
Thumbs up
Funny you mention this, I did the same for my '92 when I went from the 70A 2G to 130A 3G. Just found an OE harness and installed into mine, worked great with no screwing around. Sticks in my head the thing is 6awg. Sound right?
Old Aug 31, 2023 | 03:37 PM
  #29
Anonymous12
This is what I was gonna get for all the wiring.
Am I missing anything? The voltage regulator will plug into it like the old one, and then I take the old wire out from the alternator and solenoid and put the new cable in with the 200A fuse? Or do I have to be connecting some other stuff and splicing the old harness?
I was going based off this.
These are the plugs on my new one
Old Aug 31, 2023 | 05:56 PM
  #30
Anonymous12
I have a voltmeter in the cluster right? I won’t need to disconnect it?
