Can i test run engine without up/down pipe?
Old Aug 19, 2023 | 06:40 PM
groundhhogy's Avatar
groundhhogy
I want to test fire my engine to watch oil come out of my injectors before buttoning everything up. It would be easier to just run it a couple minutes at idle without the up and down pipes installed.
Is that ok?
Old Aug 19, 2023 | 07:05 PM
Tpayne621's Avatar
Tpayne621
Yea it won't hurt anything just idling to check for oil.
Old Aug 19, 2023 | 08:35 PM
Kwikkordead's Avatar
Kwikkordead
You can run a diesel engine without intake or exhaust manifolds if you want to. Their basic design is 100% air all of the time and only inject enough fuel to get the job done for whatever load requests are made to the injection system. Way different than a gas engine that chokes down the intake to a vacuum and meters out the fuel/air ratio to the engine in measured amounts according to demand.
Old Aug 19, 2023 | 11:18 PM
groundhhogy
Oh that is interesting. I didn’t know that.
Im not as knowledgeable on diesels.
And never had a turbo before either.
(i should be smarter, as i have a little 2 cyl diesel on me boat)
Old Aug 20, 2023 | 02:37 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Go for it!
I'm not your neighbor sleeping off the night before.
Old Aug 20, 2023 | 04:27 PM
groundhhogy
Hmm.
now you guys have me scared already! Lol
So will it sound like a jet engine or something?
Old Aug 20, 2023 | 05:36 PM
FinnishStroker's Avatar
FinnishStroker
It just will be loud.
You do have turbo in place?
​​​​​​Otherwise it will shoot oil from turbo pressure line!
Old Aug 20, 2023 | 06:25 PM
groundhhogy
No just the up/down pipes off.
And the tiny red/grn enironmental? lines. Goes to waste gate solenoid?
Old Aug 20, 2023 | 07:26 PM
jstihl's Avatar
jstihl
Having the red and green lines removed won't hurt anything, a lot of us remove those permanently
Old Aug 20, 2023 | 07:39 PM
Tpayne621's Avatar
Tpayne621
X2. Throw them in the trash.
Old Aug 20, 2023 | 09:00 PM
RacinJasonWV's Avatar
RacinJasonWV
Be sure there is nothing loose near the intake ports. These engines move a TON of air. It may suck up anything in the general area.
Old Aug 20, 2023 | 11:11 PM
groundhhogy
Suck up things? Like the plastic baggies i forgot to remove? Lol. I caught it in time.
Im in Az and you have to protect against fine grit that blows around. But It wasn’t really that noisy. Kinda more like normal.
Anyway they all spit oil except one. #5. This alarmed me. My old friend anxiety came to visit until i noticed #5 connector slipped loose.
Which brings up my next questions.
those connections under the valve cover seem awful loose for a vibrating motor.
Q: is there some way to pinch those little metal locking arms so they grip better?
Old Aug 21, 2023 | 01:32 AM
FinnishStroker
I guess one could try to press with a pliers from the sides of that metal clip.
Old Aug 21, 2023 | 01:33 AM
groundhhogy
I’ll try that tomorrow.
Old Aug 21, 2023 | 06:40 AM
John in OkieLand's Avatar
John in OkieLand
I have used medium sized Needle Nose pliers to lightly crimp the slip over connectors, so that they grip the spade lugs tighter.
be easy though, you can get them too tight, and make them useless.
