Sponsored by: Real Truck
Maintenance Question
Old Aug 17, 2023 | 02:06 PM
prginocx's Avatar
prginocx
2009, 74k miles, 5.4L V8, XLT, Super Duty, AT, PS, PB, 4X4 8 ft bed, supercab.
Another person on here helped me, so I finished replacing the rear Diff. Fluid, that went smoothly. All my other maintenance went fine, I was thinking about doing the serpentine belt, although its a bit early. All this is 'cause I'm planning a long trip in October to Montana, will do some 4x4 for sure.
I'm wondering you'all opinion on the serpentine belt replacement, yeah or nay ? On my generic maint. schedule it says grease the suspension fittings. The only ones I found are the drive shaft where it goes onto the front hub, 1 Zerk fitting on each side. I can't find any others ? I seem to remember a debate on where/when they started eliminating Zerk fittings and just went with all sealed bearings every where. Am I missing some ? As you can see from the mileage, the truck sits mostly...I only use if for RV type trips with a Cabover Camper. Sometimes towing a 1200 lb trailer. It does everything I want, just has pretty awful gas mileage. I had the plugs swapped at the dealership, because you'all warned me it was tricky. Their appearance seemed to indicate very clean combustion, all 8 cyl.
Old Aug 18, 2023 | 06:29 AM
user 195474726373's Avatar
user 195474726373
For piece of mind you can carry a new serpentine belt with you.
Old Aug 18, 2023 | 11:50 AM
prginocx's Avatar
prginocx
I did think of that...My understanding is the main tool you need is a long handle 1/2" square, to release the tension. And then you just thread the belt according to the diagram, good to go ? So if you have the spare belt, and the tool, not a tough on the trail fix...
Old Aug 18, 2023 | 12:48 PM
99powerstrokedF250's Avatar
99powerstrokedF250
That's correct, it's pretty simple and quick to do as long as you don't have to unwrap the old belt off any pulleys.
Generally speaking, I used to put the new belt on and put the old belt under the back seat, in a box with every idler/tensioner pulley and the tools to replace them. Never had to make an emergency repair like that, but it was comforting to know I had the parts and tools.
Nowadays I don't - I don't usually travel to the boonies anymore, so I'm usually close enough I can get help fairly quick.
Old Aug 18, 2023 | 04:37 PM
redford's Avatar
redford
FTE Leadership Emeritus
My 07 5.4L had 144k miles on the factory serpentine belt when I traded it in. Still looked and worked great.
I'd just carry a spare.
pilgrimbizket
Mar 31, 2019 06:45 AM
pilgrimbizket
Mar 30, 2019 02:23 PM
Greynomad
Jun 17, 2017 06:12 AM
Ranger Lance
3.0L V6
May 1, 2004 07:54 PM
