Onboard DTC Codes
Old Aug 16, 2023 | 11:17 AM
Michael W Morey's Avatar
Michael W Morey
2nd Gear
Onboard DTC Codes
2007 F 150 XL 4.2L When accessing the onboard DTC codes (Hold the odometer reset and turn on the key) the numbers/ letters are not the same as posted. Can anyone tell me what I am doing wrong?
Old Aug 16, 2023 | 01:39 PM
projectSHO89's Avatar
projectSHO89
What are you trying to do? The odometer "codes" have very limited usefulness. If one does not know how to utilize them for their narrow purpose, one will usually end up down a rabbit trail.
Any codes present in the cluster will only be for the cluster itself, not the PCM or any other subsystem. Those require a "real" scan tool, reader or comparable.
Old Aug 16, 2023 | 11:33 PM
tbear853's Avatar
tbear853
I have had mine since 2009, I never knew it could show codes. I use a Scan Guage II and I have a separate code reader.
Old Aug 16, 2023 | 11:42 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
A simple code reader like at Walmart reader would probably give more usable results.
ajmicek
6.4L Power Stroke Diesel
Feb 6, 2014 05:04 AM
noshow
13
Jan 19, 2011 02:56 PM
High Binder
Nov 15, 2010 04:36 PM
rwdfan
Sep 11, 2009 04:21 PM
eco
Jan 27, 2006 09:12 PM
