Dana 60, and 50 compability
Old Aug 16, 2023 | 10:51 AM
94obs's Avatar
94obs
Hey guys!
Im fully rebuilding a 1989 kingpin Dana 60 off of my F350 parts truck. I am going to be putting it on my 1994 F250 in place of the ttb. It was in rough shape, so just about everything needed replaced. I have purchased kingpins, seals, bearings, bushings. everything that can be replaced aside from the carrier, and pinion.
my question… I would rather not buy new brakes and hubs and manual locking hubs because the brakes are pretty new on my 94. I am on with buying new calipers if needed.
but, will the caliper arms, dust shields, rotors, hubs and locking hubs off of the 94 ttb all fit on my Dana 60?
Old Aug 16, 2023 | 03:11 PM
94obs's Avatar
94obs
I assume I’m using the right terms? I’m 18 I’m trying to learn about these things but I also want to keep it semi cheap… When I say hub I was talking the entire setup with wheel studs, and bearings and rotor. And then locking hub I have an all but new warn manual lockers that the previous owner put in 3 years ago. I would like to use those. I would also like to use the caliper arms off of the Dana 60 too if possible. But if I need to use them off of the ttb that’s fine. I haven’t torn my ttb apart yet so I don’t really know what I’m dealing with there. But the Dana 60 is totally stripped, sandblasted and partially rebuilt as we speak.
Old Aug 16, 2023 | 06:32 PM
JJF20's Avatar
JJF20
A few links to help get you started.. I don’t know enough about the ‘89 D60 to comment.
Your D50 spindles will not work - they may physically fit, but they are not the same depth into the knuckle bore.
https://www.ford-trucks.com/forums/1...questions.html
BillaVista.com-Dana 60 Front Axle Bible Tech Article by BillaVista
Old Aug 17, 2023 | 05:18 AM
94obs's Avatar
94obs
Yep, I plan on using the spindles off of the 60. It was the hubs and locking hubs I was more concerned about. Thanks, I’ll check out the links
Old Aug 17, 2023 | 07:46 AM
tjc transport's Avatar
tjc transport
i ain't rite
hubs and locking hubs will interchange.
Old Aug 17, 2023 | 08:40 AM
94obs's Avatar
94obs
Awesom, that’s what I needed to know. Thanks!
Powersmoke_sd
Sep 4, 2017 01:26 PM
shorerider16
May 8, 2016 11:16 AM
TheWedge1
Dec 4, 2010 11:14 PM
super440
Offroad & 4x4
Sep 20, 2004 08:39 PM
