So I just picked up this truck and can't get it running on its own got injector pulse 35 to 40 psi of fuel pressure have spark. It'll run as long as you force feed it. What are your thoughts on what I should chase
Just because the injectors are pulsing and there is pressure does not mean it is spraying fuel. I found most of the injectors on the Bronco II were clogged from the truck sitting so long.
Just tried to start my truck with gas pedal to the floor. Truck didn't crank right up but, it cranked up a whole heck of a lot faster than normal off the gas pedal crank up after sitting a while...any help greatly appreciated.....
