No Audio
Old Aug 12, 2023 | 01:24 PM
Steve0izded's Avatar
Steve0izded
2nd Gear
No Audio
Hello,
I have a 2022 F250 Lariat trim and recently I have been having an issue with having no audio. When attempting to turn on the audio, it does not. I have done a master and soft reset and when it completes the process, I can then see the options of the audio source (Bluetooth, am,fm etc) but when I click them, nothing happens. I then can turn it off but then turning it on will not happen. When it is on, the volume **** does not work either, it stays at 0. I can navigate in the infotainment and CarPlay just can’t get the sound to work. I pulled the amp and radio fuse and nothing. Any advice?
Old Aug 12, 2023 | 02:34 PM
Split rims's Avatar
Split rims
Disconnect the battery/batteries for 20 min.
Old Aug 12, 2023 | 03:24 PM
Steve0izded
2nd Gear
Just tried that and still the same thing.
Old Aug 12, 2023 | 04:03 PM
Poncho450's Avatar
Poncho450
Might be the APIM. Not sure if this will help or not -
https://fordmasterx.com/how-to-reset...pand_article=1
Old Aug 14, 2023 | 08:54 AM
Ford Motor Company's Avatar
Ford Motor Company
Official Ford Pro Rep
Originally Posted by Steve0izded
Hello,
Hey there. Can you send over a message with your VIN and the name/location of your local Ford dealer? I would like to see what I can do to assist with your truck's audio issues.
Old Feb 15, 2024 | 08:49 AM
highoctane74's Avatar
highoctane74
Anyone find a fix? Having the same issue on a 2002 F350.
Old Sep 5, 2024 | 09:42 AM
chuck68's Avatar
chuck68
1st Gear
Anyone find a fix? Having the same issue on a 2017 F250.
Old Jan 5, 2025 | 06:37 PM
osbie20's Avatar
osbie20
4th Gear
Radio has no sound
Hello,
Did you ever get this taken care of? I’m having the same issue…
Old Jan 5, 2025 | 06:40 PM
osbie20's Avatar
osbie20
4th Gear
can you help as I am having the same issue?
Old Jan 5, 2025 | 06:46 PM
Black Buzzard's Avatar
Black Buzzard
I had this problem on my 2022. Did all the resets, soft, hard and master. Also pulled/replaced fuses. There are separate fuses for sync, radio, and amplifier as I recall?
Did all the above several times, and then suddenly it all worked again. Problem has not returned.
Old Feb 27, 2025 | 11:18 AM
riveraj83's Avatar
riveraj83
7th Gear
seems to be an ongoing issue as I'm dealing with something like it now and so are some other fellas on here and one is paying to have this fixed. Mind taking a look? @Ford Motor Company
https://www.ford-trucks.com/forums/1...io-issues.html
Old Aug 12, 2025 | 10:02 PM
Mooregon's Avatar
Mooregon
2nd Gear
Im having same issue. 2022 F350 Platinum Dually. SYNC screen looks ok. No Audio. SYNC audio buttons, and manual volume **** do not respond.
Old Aug 13, 2025 | 07:50 PM
MagicMtnDan's Avatar
MagicMtnDan
Could this be part of the SYNC recall (NHTSA Recall 25V442)?
If so, ugh! "Software is not available. FMC is working to provide software for this repair. The remedy is anticipated to be available the third quarter of 2025."
Old Aug 30, 2025 | 09:38 PM
Mooregon's Avatar
Mooregon
2nd Gear
Repaired
I ended up taking it to the dealer. They had it two full weeks. They tested/reprogrammed everything tied to the audio system. Ended up changing out the Audio Control Module (ACM) p/n LC3Z18K810J.
It was all covered by warranty. Pretty sad the part broke, even worse it took so long to figure out the problem. My local shop seemed to be working hard, but Ford home office was dragging their feet, slow to respond.
SeannyBoy84
Oct 15, 2006 09:57 PM
diesel2x
Nov 12, 2005 05:35 PM
goldbach_d
Jan 13, 2004 05:19 PM
porkinbeans
Sep 7, 2002 08:42 PM
