Am thinking of putting a 351 with manual tranny into my '50 F-1. I need to know what rear end it should have put in and how hard it is to change out the rear end.
I was told before that I could leave the same rear end in as it is the one that came with the '50 but was also told with the original the most speed I could expect to get would be around 50 MPH
With a stock 49 engine I would expect more than 50mph ..... HP & gear ratio will determine your speed not what type of rear end you have. Stock rear ends work fine with mild engine / trans upgrades and can handle up 300hp.....so they say.
Not knowing the ratio of what you have now it is hard to say what the top speed would be.
I am guessing they said top speed of 50 with the factory motor and rear.
The newer motor will have more power and spin a lot higher so the top speed would be more.
But with that said if the ratio is too low the new motor may be spinning a lot more than you may want.
What will also help on what ratio to run is what will the truck be used for and what transmission you plan on using.
Dave ----
Thanks for the information, I am trying to leave the pickup as original as possible. had a 239 in it but the block was cracked and haven't had any luck finding another
Do you know of anyone that has just a block for a 239? The old style with the distributor on the right front. I saved all of the pieces from the old engine and looking for a block
A 351 or even a 302 would make a really nice driver out of your truck. The stock rear typically came with 3.91-4.11 gears and the rpm's tend to run high at highway speeds. The modern v8's would be much more comfortable with something closer to 3.25 and let you drive on the freeway more comfortably. The easiest and cheapest way to do that is with the F100 9" swap as mentioned. And yes, that does mean replacing the entire rear axle assembly. It's not as difficult as it sounds.
