I am thinking
Old Apr 15, 2022 | 07:02 PM
ynot321AB1's Avatar
ynot321AB1
I am thinking
That in itself is scary, LOL. I am thinking of putting a 351 windsor into my '50 F-1 and wondering if the rear end can take the torque?
Has anyone put one in this type of vehicle and what problems did you have? I have removes the rear end cover and cleaned it to the best of my ability and everything looks good.
Old Apr 16, 2022 | 11:05 AM
CharlieLed's Avatar
CharlieLed
It may hold the torque but would you be happy driving it? That 351 is going to want to go and the OEM gears are not going to let it.
Old Apr 21, 2022 | 08:43 PM
Jules The Great's Avatar
Jules The Great
Wouldn't the oem gears be around 4:88 in the back, thing would bunny hop when you stomp on the gas.
Old Apr 21, 2022 | 10:58 PM
52 Merc's Avatar
52 Merc
An F1 would have a Dana 41 or 44 with most likely 3.92 gears, but also possible to be 3.73's or 4.11's. Either way, she'll be taching out pretty high on the highway, and the 351 would appreciate 3.00's or 3.25's much better. That's the biggest reason why most guys will swap in a F100 9". They're cheap and plentiful (or were), it bolts in and typically has those gears already in it. The 4.88's would more likely be found in an F2.
Old Apr 22, 2022 | 03:15 AM
49willard's Avatar
49willard
I drove my 49 F-1 for a number of years with a 56 Nailhead Buick thru the stock rear without issue. If you pair the 351 with an AOD or OD manual Trans and avoid beating on it I believe that you will be fine and happy with highway RPM.
Old Apr 22, 2022 | 07:22 AM
EBEAR's Avatar
EBEAR
As 49willard said if you are changing engines you will be changing trans also so simply put in an overdrive and problem solved .
Old Apr 22, 2022 | 07:29 AM
ben73058's Avatar
ben73058
Hmmm... We have a 50 F1 with a 351 Windsor. If you are going to go through
the work needed to put in a new engine Ynot put in a solid transmission & rear end to go with it.
The rear end install is at most a weekend's effort. We went with a salvage yard Explorer 8.8 with 3.73 gearing, limited slip
diff. & disc brakes. It's a smooth highway cruisier mated up to an AOD transmisson.
The original rear end has a pretty restrictive gear set - pretty high rpm's at highway speeds.
Good luck over there in Arkansas - you'll enjoy the Windsor.
Ben in Austin
1950 F1 (351W/AOD)
Old Apr 22, 2022 | 09:56 AM
Blue50F-1's Avatar
Blue50F-1
I've had a 302 in mine for years, with an OD trans and the original rear I could cruise down the highway okay, but I snapped an axle a few years in and swapped out the rear end for a 9" that the seller said was out of a 63 F100. 3.25 gears made highway cruising super easy and the swap was a bolt up affair. Totally worth the work, especially if you're already swapping out the engine and trans.
cpetersen
Apr 3, 2012 01:27 PM
jimford1
19
Jan 6, 2010 12:15 AM
Engine
16
Oct 15, 2009 07:16 AM
LedheadELH
Dec 6, 2004 12:02 AM
56restore
Jun 24, 2004 01:31 PM
