Sponsored by: Real Truck
can both knox sensors set same time?
Old Aug 10, 2023 | 07:00 PM
porgey's Avatar
porgey
4th Gear
can both set codes same time?? got P220A P220B same time...also set a P04E3 crankcase vent sensor high? Its 2014 F550 has 61K on it does a lot of idle..its a dump body with plow....Has set both Knox before a month ago i cleared then..been off till today also P04E3 came today....Its had some temp sensor codes for exhaust replaced them sensors they stay away...Soooo through 2 Knox sensors at it?? and that vent box on valve cover??? If had bad harness somewhere should come back all the time i think??? it had its recall on ecm 2 yrs ago...any thing else out there I'm missing??? THANKS GUYS!!
