Front Axle Service
Old Aug 10, 2023 | 05:38 AM
GavinAtkins's Avatar
GavinAtkins
Front Axle Service
Good Morning,
My Vacuum lock hubs have seemed to quit working in the past 6 months. I’m wanting to take apart everything around the outer ends of the front axle and rebuild all the wear parts.
I’m working on building a list of all the parts I need. I’m not planning on changing the Unit Bearings or the stub shafts unless they’re damaged. Where I’m gonna be doing the work has spares, but I don’t think my truck has any issues.
Any words of advice? Or if anyone has a parts list that would be greatly appreciated!
Side note, I’m doing my diff fluid at this time. Anyone know off hand how much it takes? I’ve seen everything from 1.5 to 5 quarts online.
75w-140, right?
Old Aug 10, 2023 | 05:55 AM
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by GavinAtkins
Good Morning,
75w-140, right?
If the auto hubs quit working, there is a good chance your knuckle seals and/or the flex lines from frame to knuckle have failed. In any event, the manual calls for the knuckle seals to be replaced any time the front axle is serviced. Do an end-to-end check for vacuum leaks in the line from the vacuum reservoir, through the vacuum solenoid valve all the way to the knuckles though. Those vacuum lines tend to get crispy with age.
Not many parts to replace if you do not plan to replace the unit bearings. The knuckle seals I told you about already. You may or may not want to replace the dust shield (some call it a seal. It doesn't really seal anything.) that goes on the inner side of the shafts up against the axle tube. Those things disintegrate quickly into rubber hula hoops around the shaft. How is the steering linkage? I will come back and add part numbers as I find them.
eBay knuckle seal and dust seal/shield set: https://www.ebay.com/itm/18579808999...3ABFBMsOSl8rti
See the attached PDF for lubricant quantity. I run Schaeffer 293 Supreme 75W-90 as recommended by them over the 751M.
https://www.schaefferoil.com/2937590-gearlube.html
File Type: pdf
Old Aug 10, 2023 | 06:48 AM
GavinAtkins
Sweet! I appreciate it!
I hadn’t thought of doing the vacuum check, but we certainly will. I’ve got rubber hula hoops right now, so anything will be an upgrade.
Im probably gonna do U joints and ball joints while I’m in there. I’ve got some crazy overtime stuff coming up and really want the truck happy through “winter” (I live in San Antonio, so winter is pretty tame)
I’m fairly green at chasing vacuum leaks. What’s the best way?
Old Aug 10, 2023 | 07:08 AM
FordTruckNoob
In that case:
XRF Ball Joints:
Amazon Amazon
Spicer U-joints:
Amazon Amazon
The u-joints are the non-greasable type which are stronger. They come with lifetime grease.
As for vacuum leaks, I like to plug one end, apply shop air gently and spray soapy water. Then when I still had to jump out to lock the hubs 50% of the time I switched to manual hubs and got rid of the 4x4 vacuum crap.
Old Aug 10, 2023 | 11:46 AM
GavinAtkins
In that case:
XRF Ball Joints: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Spicer U-joints: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thats the exact u joint I use. Spicer lifetime nongreasable are the only ones I use
Wjats better about the XRF ball joints?
Old Aug 10, 2023 | 11:57 AM
FordTruckNoob
Good reviews at the time I went with them. Still relatively few complaints now. I cannot speak to their construction versus other makes since all the ball joint makers (except Dynatrac) seem to think it is some sort of industrial secret.
Old Aug 10, 2023 | 12:51 PM
knottyrope's Avatar
knottyrope
after dealing with a spicer failure in a few months, i went to XRF greaseable ones and they have a million mile warranty
The Frenchtown Flyer
Aug 1, 2022 02:36 PM
jkg234
Large Truck
Jan 7, 2017 04:02 PM
grm61
Mar 28, 2010 06:10 PM
mikefox670
2004 - 2008 F150
13
Jun 10, 2005 07:14 PM
