Axle Gear Ratios
Old Aug 9, 2023 | 08:12 AM
68$hevellE's Avatar
68$hevellE
8th Gear
Axle Gear Ratios
Looking at purchasing a used 2020 F250 Lariat with 3.31 Axle. I currently have a 2011 F250 King Ranch with 3.73 Axle. My question is what Axle is best for towing and mileage with the newer 10sp Super Dutys? I see some with 3.55 also. I currently have a 36ft 5th wheel that weights around 11k loaded. Thanks
Old Aug 9, 2023 | 08:54 AM
acadianbob's Avatar
acadianbob
Hmmmmmmm. I'm not sure Ford makes a 3.43.
The best towing axle is the biggest number IMO.
Just towed my 11.5K 5er 2K miles to Cody and back. Running 4.30's. Can't imagine towing 11.5K with anything else.
8.8 mpg out and 8.5 mpg back. More 70 mph and more wind on the way back.
Old Aug 9, 2023 | 09:10 AM
GAZZILLA's Avatar
GAZZILLA
Originally Posted by 68$hevellE
My question is what Axle is best for towing and mileage with the newer 10sp Super Dutys? Thanks
You can’t have it both ways, either they’re good for towing (4.30’s) or they’re good for higher MPG driving empty at higher speeds 3.55/3.73’s.
Let the axles ratio SHXX STORM thread begin!
Old Aug 9, 2023 | 09:23 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Looking at purchasing a used 2020 F250 Lariat with 3.43 Axle. I currently have a 2011 F250 King Ranch with 3.73 Axle. My question is what Axle is best for towing and mileage with the newer 10sp Super Dutys? I see some with 3.55 also. I currently have a 36ft 5th wheel that weights around 11k loaded. Thanks
You didn't say which engine is in the 2020.
There is no 3.43 ratio.
Ford never offered anything but 3.31, 3.55, 3.73 or 4.30 ratios in Super Duty trucks, and only certain of those ratios with certain engines.
So, we need more info on the truck combo you are looking at.
But, most any would tow a 11K 5th wheel.
Old Aug 9, 2023 | 12:28 PM
redford's Avatar
redford
FTE Leadership Emeritus
The answer for best ratio depends on the engine, but a higher ratio (numerically) is always a good thing when you're towing.
Old Aug 9, 2023 | 01:15 PM
speakerfritz's Avatar
speakerfritz
exactly……..
Old Aug 9, 2023 | 01:38 PM
68$hevellE's Avatar
68$hevellE
8th Gear
My bad, you are correct, it is a 3.31 and its the 6.7l not a gasser, thanks for pointing that out, I corrected.
Old Aug 9, 2023 | 02:02 PM
OBS460's Avatar
OBS460
3.31 in a diesel F250 will tow 11k lb 5th wheel just fine if my 95 460 can tow that much and it is rated for less than some half tons today.
Old Aug 9, 2023 | 02:44 PM
Leardriver's Avatar
Leardriver
You have the 10 speed trans, and all the gear ratio means now is whether it is in 5th or 6th when climbing a hill. It is a game changer.
Old Aug 9, 2023 | 04:28 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
That engine/trans/rear axle combo will tow anything you hook it to without breaking a sweat.
I've pulled 14K actual weight trailers with my 2022 F250 6.7 3.31, no issue what so ever.
Old Aug 9, 2023 | 05:22 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
3.55 will tow better (barely)
3.31 will get better MPG (barely)
I say barely, because they are so close, it's a toss-up. Don't sweat whatever they are...just pick the best overall truck you like.
Old Aug 10, 2023 | 05:30 AM
BDWSD22's Avatar
BDWSD22
Happy with 6.7L / 3.55 11.4k RV
I've had both the '20 & '22 F-350 6.7L SCLB with the 11.5k GVWR & 11.4k GVWR respectively, both with 3.55:1 and they both tow spectacularly. Unloaded mpg is 20+ @ 55mph with brush guard, front hitch, Tremor front panel and 275/65R20 Michelin All Terain 10 ply at 67 psi cold.
Towing 11.4k lbs easily @ 70mph is 11-13mpg due to 12.5'x8.5' frontal area of my RV and variations of terrain. The towing mpg improves at 55mph due to reduced wind resistance. Flat roads, good fuel and 50mph to 60mph gives close to 15mpg towing the same rig. I'm older and drive conservatively mostly.
We don't buy SD trucks for their mpg, really. We buy them to do work and haul heavy loads. They do that well. It's hard to beat the 6.7L/10-speed for towing.
Old Aug 10, 2023 | 06:03 AM
Joe T's Avatar
Joe T
With stock sized tires that should be fine.
If you have scaled it maybe check the weight against the white sticker but there are so many gvwr combos in these its hard to give advice.
Old Aug 10, 2023 | 08:50 AM
tsmithco's Avatar
tsmithco
2018 250 6.7 w/ 3.31 and 6 speed tows my 14k fiver no issues from Ohio to Ocean City Md.
2022 350 DRW w/ 3.55 and 10 speed tows buttery smooth with all those gears. if 3.31 was an option I would have gone that route because first gear wants to pull an entire house!
Old Aug 10, 2023 | 09:08 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
Gear ratios always opens a can of worms. I add my experience. I had a 2015 F250 6.7 L with 3.55. Normal driving I got about 13 MPG. Put a 10k Fitth wheel on it miles were 9.5 to 10.5. Traded for a F350 DRW 6.7 L with 4.10 gears and 10 speed. Current milage Mosty town is 13.5-14. and 10 to 11 with trailer.
