SHIFTER LEVER
Old Aug 8, 2023 | 03:51 PM
Rad082625's Avatar
Rad082625
SHIFTER LEVER
I'm redoing the interior of my 1967 F-250 CS and want to go to a steering wheel with less dish than the factory wheel which has a fair amount of dish. The C6 shift lever has the angles that match the stock wheel but will interfere with the new wheel with less dish so I want to take the lever off and re bend to match the new wheel. My question is: can I simply pop the spring pin out and pull out the lever or do I run into any problems putting the lever back in after I reshape the lever? thanks...Bob
Old Aug 17, 2023 | 09:31 PM
JEFFFAFA's Avatar
JEFFFAFA
I'm not 100% sure, but I can't imagine you having trouble. Inside the column should be "at rest" until the lever is pulled back towards the driver.
Old Aug 18, 2023 | 07:09 AM
Rad082625's Avatar
Rad082625
Thank you...Bob
DoubleStacks OBS
Jul 31, 2023 07:20 PM
F260y
Nov 30, 2022 06:51 PM
nsxtac
Feb 8, 2018 03:17 AM
RangerRider460
Oct 7, 2005 12:43 PM
bluebronco88
1978 - 1996 Big Bronco
Dec 17, 2004 09:21 AM
