Rearview mirror placement question
Old Aug 8, 2023 | 09:43 AM
The Black's Avatar
The Black
Hi Guys and girls,
My granddaughter accidentally pulled the rearview mirror off my '79. There is a remaining mark from the location but I'm not sure if it's the original factory spot. My search didn't quite answer the question....Should the mirror be centered side to side? The glue mark now is not, it's off the the passenger side about one inch.
TIA
Old Aug 8, 2023 | 10:38 AM
Mark8man's Avatar
Mark8man
Yes exactly centered side to side. The height position looks about right.
Old Aug 8, 2023 | 10:51 AM
tbear853's Avatar
tbear853
A bunch of years ago, after it fell a couple of times, I fixed it but good. I measured and cut a piece of about 1/16" steel about 2" wide, maybe 3" long, drilled the mounting button, glued and screwed it to the metal, painted it black, then mounted that to the cab metal above the windshield with two sheet metal screws, then mounted the mirror. It's a little higher, but I can see the whole tailgate inside if needed ... and I had a thermometer hanging there this day. The mirror is higher up so I see more out the windshield, but it's still low enough I can see the vehicles behind me ... and it'll never fall on a hot day now ... nor will it ever pull a chunk of glass out with it.
Factory ... I always thought was too low, but it was centered.
Old Aug 8, 2023 | 11:13 AM
The Black's Avatar
The Black
This has to be the original glass. Here’s the stamping, anyone date it for me?
Old Aug 9, 2023 | 05:17 AM
FuzzFace2's Avatar
FuzzFace2
I will say for anyone wanting to mount the button and dont know where it goes do this.
With mirror in hand hold it up to the glass and then move both sun visors to make sure they clear.
Now mark the glass around the mirror then on the out side do the same as you will be removing the inside mark when cleaning the glass.
Follow the directions of the button glue and mount the button to where the mark is on the outside.
Clean the mark on the outside and if done right the visors should clear the mirror when mounted.
I found a grease pen worked for marking as it wipes off.
Dave ----
Old Aug 10, 2023 | 07:42 PM
tbear853's Avatar
tbear853
March 1977
moejr
Feb 10, 2023 05:40 PM
koboss1
6.4L Power Stroke Diesel
Jul 6, 2011 01:00 PM
dunney1
Jan 15, 2010 10:58 PM
peganit2
Jan 19, 2009 08:52 PM
ssnh
Jul 16, 2007 08:08 PM
