Bushings for frame need replacing.
Old Aug 7, 2023 | 06:39 PM
joe4law's Avatar
joe4law
1982 F-250 4 wheel drive with 6.6 liter engine and 4 speed manual. Need to replace the bushings between the frame and body. Any suggestions on the best bushings to buy? One bushing is gone and the others are worn and cracked. Also, the best tool for removing and replacing them?
Old Aug 8, 2023 | 02:00 PM
Franklin2's Avatar
Franklin2
This is one of the worst jobs you will do on these trucks. The stock bushings use a sleeve and a bolt, and that all rusts together making it impossible sometimes to get apart. When I did my Bronco, I had some that were stuck and I let the impact spin the whole thing at high speed till it melted the rubber and fell out.
The stock rubber bushings give you a decent quiet isolated ride. I used the poly bushings, and while they made it handle around corners like it was on rails, they are noisy and you can hear every gravel in the road and you can also hear the transmission and the rearend more.
Check those brackets when you get the bushings off. My f250 bracket on the front pass side was rusted through, and on the f150 I had the rear cab bushing brackets were rusted through. On my Bronco, two of the frame brackets where rusted through. You can get flat pieces of metal and weld them on the bracket to fix it.
the cleaner
Modular V10 (6.8l)
Aug 16, 2014 05:42 AM
Shade
Aug 28, 2009 11:52 PM
needyourhelp
Feb 13, 2009 10:19 PM
Rocking M
Aug 25, 2003 12:57 PM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
May 20, 2003 10:43 PM
