4R100 diagnosis
Old Aug 4, 2023 | 05:00 PM
F350towing's Avatar
F350towing
4R100 diagnosis
Just spent 5 hour round trip to end up back home.
2-1/2 into our journey transmission started slipping only in 3rd after TC lockup. Everything else worked as it should.
Pulled over at first safe turnout.
TFT was 210°, SDK tune 65 tow. 8500# trailer on the hitch.
FORScan was not running and tablet was dead so couldn’t hook it up once the problem arose.
Returned PCM to 00, and headed for home.
Once the trans cooled a bit 160-170 TC lock in 3rd didn’t slip.
Is she in her dying throes and by gods grace got me home, or is there something simple I should have a tranny shop look at first?
Got a line on a RDP stage 1.5 for $3200 including TC. Should I pull the trigger or have mine looked at???
Old Aug 4, 2023 | 07:07 PM
F350towing's Avatar
F350towing
Spoke with a transmission shop.
3rd in TC lockup is the direct drive clutch. Could be failing in more ways than one.
Got this guys shop from a buddy, turns out he builds transmissions for SDK’s race truck.
Truck goes in on Tuesday morning for a re-re. He’s got one on the shelf for me and bumped a couple of things to squeeze me in.
Old Aug 4, 2023 | 10:56 PM
Kwikkordead's Avatar
Kwikkordead
That was quick. 2 hours 7 minutes between question post and answer post.
Old Aug 5, 2023 | 02:39 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Just FYI 210F is no worry.
Long time at 225F or short time at 250F is the danger zone if IIRC Mark K correctly.
6.0 trans cooler if you don't already have one.
Old Aug 5, 2023 | 08:07 AM
F350towing's Avatar
F350towing
Yeah I was aware of that for temps. Thanks David.
I does have an aftermarket cooler on it already.
I was mentioning temps since when it did cool down 40ish degrees no more slipping.
When we turned around it also was downhill to the valley out of the Fraser Canyon.
Back to stock tune also helped with a decrease in demand.
I won’t say I was driving like a granny but I did get passed by more than one Semi.
Old Aug 5, 2023 | 01:24 PM
John in OkieLand's Avatar
John in OkieLand
this one?
Old Aug 5, 2023 | 03:01 PM
F350towing's Avatar
F350towing
Originally Posted by John in OkieLand
this one?
Probably not but that is what they looked like as they went past me on the uphill pulls as I was nursing it in 2nd.
Old Aug 6, 2023 | 01:28 AM
carl2591's Avatar
carl2591
when you do trans do flex plate and TQ with triple disk billet.. Sam Wyse sell them.. that what he does on the stage 1 rebuilds I got.. summit racing flex plate is same money as OEM and better..
Old Aug 6, 2023 | 09:53 AM
F350towing's Avatar
F350towing
Spoke with Rob at Summit Performance Transmissions for about 1/2 hour. He asked me a lot of questions first for the diagnosis, then about my use of the truck and future upgrades.
A billet TC is what he recommended for my usage. Said he could do the triple disk but for my needs and price tag it would be a waste of my money.
His standard build is guaranteed for up to 500hp with a 2 year unlimited km warranty.
I hadn’t considered the flex plate and will have that discussion with him on Tuesday morning when I drop off the truck.
Old Aug 6, 2023 | 01:49 PM
FinnishStroker's Avatar
FinnishStroker
Triple disc TC is beneficial in all applications.
Old Aug 6, 2023 | 03:30 PM
carl2591's Avatar
carl2591
triple disk give more holding power for acceleration and when using exhaust brake if you have done that mod. I run a mild 80 DD and 60 Tow tune and can feel the difference between a single and triple clutch. its not a requirement but a nice thing to do while you are doing..
as far as the flexplate i found cracks on one iwth 223K miles and far as i know OEM from factory.. summit make a racing plate that is super good.
go to post #9 on this thread to read more.. https://www.ford-trucks.com/forums/1...placement.html
Old Aug 7, 2023 | 01:30 AM
F350towing's Avatar
F350towing
Ill ask about the cost difference on the triple disk.
Flex plate was quite the deep dive as I followed all the links to related threads. Y2K makes an excellent point when it comes to the “billet” 💪 plate. Where does it flex… what gives???
Stamped it will be. Not sure who’s yet. Depends on what Rob has available.
Found one local to me at BD diesel.
https://ca.bddiesel.com/products/7-3...39410908037174
That’s a lot of money for a chunk of steel.
Summit racing is south of me across the border with a week and a half for shipping. That ain’t happening. Transmission goes in on Tuesday.
My truck currently has 202,000 kms = 126,000 miles and in its life with me has only seen 70,000 kms = 43,500 miles in 19 years. The fact that it even needs a transmission already is surprising to me.
Directly from the transmission shop it’s going to SDK to have all the tunes modified to be back to Stock PMT2 shift strategy.
Old Aug 7, 2023 | 04:55 AM
FinnishStroker
Billet flexplate is something that is used in racing,go for OEM style.
Ask Dan K,i'm sure that he confirms that triple disc TC is something that needs to be added.
I don't know why the tranny guy don't want you to have it..
Old Aug 7, 2023 | 06:53 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
When a torque converter spins, it swells in the longitudinal direction. That is, it grows in size between the engine and transmission. The flex plate allows for this movement. If the flex plate is too stiff, such as a billet flex plate, the engine's thrust bearings take the load. This tends to wear out the thrust bearings quickly, leading to an engine rebuild.
Old Aug 7, 2023 | 07:01 AM
RacinJasonWV's Avatar
RacinJasonWV
Hi Mark,
I’m not recommending a billet plate but have a question.
Won’t the TC “snout” just move into the transmission if the plate is stiff? Isn’t the TC endplay there to allow for the ballooning and heat growth?
I do think a stiffer plate will transfer more vibration and load to the crankshaft.
Personally I feel the slightly thicker Summit SFI plate is a good balance between longevity and performance due to seeing reports of OEM plates cracking. I’m not running it, just an opinion. And I understand it’s not an option for the OP.
