Ingnition actuator rod or switch?
The key didn't want to turn this morning. Acted like the steering lock or shift lock were engaged but neither were. It eventually turned but it felt like something slipped.
The key turns from off to accessory or from off to run with little to no resistance. There are no stops for accessory, off, or run. It will just turn freely.
It will turn to start and return to run as normal. The engine cranks up and runs fine. The key itself will turn to the off position, but it will not kill the engine. Had to pull the coil wire to turn the engine off.
My first assumption was a problem with the lock cylinder. I changed that out but that did not help at all.
What's the best way to determine if it's the actuator rod or switch?
on
The following users liked this post:
Received 3,150 Likes
on
on
65rancheroguy
20
10-27-2009 12:05 PM
bretanamc
08-15-2002 11:33 AM
Rey
12-05-1999 09:20 PM
