What model Radiator Cap?
Old Aug 2, 2023 | 04:12 AM
zei220's Avatar
zei220
Hello, can anyone tell me which model radiator cap I need for my 1953 V8 flathead, please? The one fitted at the moment doesn't seal the radiator as the cap isn't long enough to reach the bottom of the radiator neck. The radiator is OEM.
Thank you for your help.
Dave
Old Aug 2, 2023 | 06:41 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
You will want a low pressure ~4psi, original Ford part number 1T-8100-A and has quite a few Ford applications, including tractors.
This seems to cross with the following:
GATES 31524
CARQUEST 10208
DURALAST 7004
Old Aug 2, 2023 | 07:14 AM
zei220's Avatar
zei220
Thank you for your quick reply. I'm visiting CO in a couple of weeks and will hopefully pick one up there.
Old Aug 2, 2023 | 11:58 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ooops -- wrong info
Old Aug 2, 2023 | 12:12 PM
bmoran4's Avatar
bmoran4
Are.you sure your numbers didn't get jumbled? I show the correct one for application being the Stant 10208 under Napa BK 7031412
Of course, this could also boil down to the multitudes of issues with cross reference
databases.
Edit: Your part numbers cross for the 41A-8100-C used through 51
Old Aug 2, 2023 | 02:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Good catch, you're right, missed that it is a 53. Stick with Stant, much better quality.
banjotx
Jun 16, 2020 08:49 PM
hotrodjohn71
Apr 25, 2016 11:22 AM
Fastback460
Feb 25, 2015 10:42 AM
john
1997 - 2003 F150
Jan 7, 2000 05:16 PM
