1978 - 1996 Big Bronco
HOW do I pull my ignition
Old Nov 19, 2003 | 06:56 PM
seans64''s Avatar
seans64'
I have an 81 full size bronco and I am trying to pull my ignition. HOW do I pull it??
Thanks, Sean
Old Nov 19, 2003 | 09:43 PM
bronc95's Avatar
bronc95
Lightbulb
Yo dude I feel your pain-check out the thread at the beginning of this forum-Ya can go to auto zone.com and check out the manual on line -it saved me a hassle and it works well
Old Nov 19, 2003 | 11:06 PM
seans64''s Avatar
seans64'
Thanks, but it doesn't show how to take the ignition out....can you explain it to me? I've got my steering wheel off, is there an ignition puller as well??
Thanks, Sean
Old Nov 20, 2003 | 04:29 AM
frogger01's Avatar
frogger01
No no no.. you dont need to remove the wheel. all you need to do is get your key and a punch or wire hanger. underneith the ign tumbler you will see a little pin hole. insert the punch or hanger in the hole and turn the key counter clockwise just past the ACC postion while pushing lightly with the punch. Once you feel the tumbler stop hard pull it out. Done deal.
Old Nov 20, 2003 | 08:58 AM
seans64''s Avatar
seans64'
ok...i lost my keys...how am i exspected to turn the key if i have no key?? this is why im stuck,is there another trick to turn the key without using the key ...
thanks, Sean
Old Nov 20, 2003 | 09:02 AM
AYoungblood's Avatar
AYoungblood
No not that i can think of.
Only other thing to do is to drill out that pin.
Pull out your emg blinkers switch.
Look under that towards iginition switch and you'll see a hole.
Drill that out and then the iginition switch should pull out with a good tug.
Adam
Old Nov 20, 2003 | 09:08 AM
seans64''s Avatar
seans64'
i was told to go to the dealer,my key is original so i should be able to get one recut..ima try that
Old Nov 20, 2003 | 06:01 PM
BOJOFASO's Avatar
BOJOFASO
are you replacing the ignition because you lost the keys? if so a locksmith can help you out by cutting you a new key with out the old one.
Yahiko
Apr 13, 2026 11:49 AM
Yahiko
Sep 2, 2013 12:28 AM
Yahiko
Jul 12, 2012 02:52 PM
Yahiko
Jul 3, 2012 12:29 AM
Yahiko
Jun 27, 2012 07:58 AM
