Do I need a new muffler?
Old Aug 1, 2023 | 12:11 PM
bigred66's Avatar
bigred66
My turbo failed and ended up dumping a ton of oil in the downpipe. Truck was smoking bad and there was wet oil out of the exhaust tip. When it failed i was about a mile from home so i drove it back. Im not sure how much oil went down the exhaust, but after a new turbo, it still blew quite a bit of black smoke for several days. Do you think all the oil would have "burned out of the mufller" or do you think it may have caked and clogged it? Trying to decide if i should replace it or not. Thanks for your input.
Old Aug 1, 2023 | 03:57 PM
IHateCommieCars's Avatar
IHateCommieCars
IDK, but it would have passed through your cat first on the way. I've heard of those getting clogged, don't know with what but assume oil, but haven't heard of clogged mufflers. I guess you'll know if you just keep driving. I'm thinking it would be something that got worse real soon, but not all at once, or else would never be a problem (from that event).
Old Aug 1, 2023 | 04:00 PM
IHateCommieCars
I'm thinking mufflers usually go bad from the other direction - floodwaters coming in the tailpipe.
Old Aug 3, 2023 | 06:38 PM
BryanStein's Avatar
BryanStein
Yep, all that oil had to pass through the kitty first. I'd be very concerned about it clogging.
I think the mufflers have too much open space in them to really clog, so a clogged muffler is very unlikely.
Old Aug 3, 2023 | 06:42 PM
bigred66's Avatar
bigred66
The truck doesn’t have a cat
Old Aug 3, 2023 | 08:51 PM
IHateCommieCars
I expect you'll be fine then, but I have no experience with that issue. Good luck.
Powerstroke.Alix
Mar 31, 2020 11:17 AM
Mike Bartlett
Apr 9, 2019 08:42 PM
Loftatsea
Nov 8, 2016 05:11 PM
tiredlr
Feb 24, 2013 01:49 PM
ZeroTucker
May 6, 2011 04:50 PM
