Source new/replacement VIN label?
Thankfully, I photographed it before leaving the truck with him.
Does anyone know if a replacement can be sourced?
Thanks in advance for your help.
https://carexpressions.net/is-your-d...icker-missing/
That may be some help, I asked google, you can too.
https://www.google.com/search?q=miss...client=gws-wiz
They advise that their sticker is intentionally not identical to the mfr label but the data is all there.
This truck can easily be verified because not only is the VIN on the VIN PLATE, but it's also stamped into the frame.
Popo's, insurance companies, and the gen public just want something to see at a glance.
Thanks again for your input.
Besides getting information what the truck came from the factory with I think he can do the sticker too.
The painter should have know better than remove it and not have a way to put it back and should have never thrown it out!
Dave ----
I was lucky and had contacts that pointed me in the right direction to a great body shop. That at that time was a mile or so away. That was back in the early 90's, I still use them when needed.
It was actually the prime reason for buying the pickup in the first place as my partner saw a paint job and a means to get part of his money back.
And that, my friends, is all the details I'll furnish as I owe no explanations beyond that. Well actually, I owe NO explanations, period. (Insert big grin here.)
This is what we started with two years ago. Mods, if I'm getting too far OT, just ****** me back. I won't take offense.
See the truck here: https://www.ford-trucks.com/forums/market/1731944
Last edited by FADECBLC; Jul 28, 2023 at 03:19 PM. Reason: added link and a hyphen, fixed typo
Getting the old truck to where it is now took me a month of forming inner roof patch panels, cutting, welding, and grinding. Critters had nested between the inner and outer roof panels and created a bunch of blowout.
I have a pair of '48 Ford big trucks (F3 and F6) that I was going to build but since I'll be 75 on my birthday and derive MUCH more pleasure from building custom guitars, I'll end it with this one.
If anyone's interested, I can start a thread showing the roof repair process.
The sticker on mine had over spray on it when I got the truck.
Vary careful I used thinner on a rag to wipe it off.
You have to watch that the thinner dose not melt the sticker so go easy.
I then used masking tape to cover it when doing any work in the area and painting the door jambs.
How did the critter get between the roof panels?
Someone danced on the roof of my truck to the point the inner panel was also pushed down.
It was fun (not) pulling the outer panel, after taking all the body filler off, and then push the inner panel back up.
Dave ----
Once there, they can travel at will the entire area above the ceiling between the inner & outer panels.
They steal jute material from the floor mat underlayment for nesting material and once they've built the nest, they urinate in it, and who knows what else.
Gravity being gravity, that liquid migrates downward through the nest and is held in place against the unprotected metal, eventually resulting in blowout.
As you can see above the RH door, there's quite a bit of shape in the metal and while it's not immediately evident, the 10" pieces in the upper RH & LH corners of the rear window took a bit of doing as they required inner and outer patch panels.
Believe it or not, I got all of that cutting, grinding, and welding done WITHOUT scratching or etching the windshield, only to have the idiot painter break it when he re-installed the hood. Oh, there I go again. SAW-ree.
Where you see a piece of hanging green tape, that indicates a factory spot weld.
break
break (I'm learning)
Withe your patch panel clamped in place (this should go without saying but I'll mention it for those who've never attempted it B4), use one hand to push it tight to the parent metal and the other to make your first tack.
Continue in that fashion until you've made all your tacks, spaced a half inch or so apart. Then, as you might imagine, it's simply a process of ultimately connecting the dots by placing a VERY short weld between each tack, and finally, closing all the gaps.
Everybody who's done this more than once has his own method but mine was developed over 40 years of coachbuilding.
In the photo below, it was a perfect time to close up the old screw holes left behind by some long-ago gun rack, both upper and lower. Notice, however, that the bed rails are undamaged though the truck was 38 years old when I shot these pix.
That was a great help in terms of work saved.
