Battery not charging
Old Jul 27, 2023 | 04:43 AM
ksmach1's Avatar
ksmach1
Just want to share my battery charging issue at last weekends camping trip. I selected the auto level mode and within 30 seconds everything stopped and the level unit screen shut off. I then checked the breakers and fuse panel and all was good. I had a multimeter and checked the battery, I was only getting 9 volts. The battery was 4 years old and its possible that it would not hold a charge. I purchased a new battery and installed it and the auto level worked like it should but nothing was recharging the battery according to the multimeter. I then set out to find the converter. It was located in the front storage compartment behind a panel that was held in place by screws. Once I removed the panel the converter was right there and I could see that it had a 35 amp fuse. I replace the bad fuse and the charging system was back online. The one tool I wish I had with me was a cordless screw gun. It took some time to remove the 8 panel screws.
BTW, I had the old battery tested and it would not hold a charge
2020 Heartland Torque 371 Toy Hauler
Old Jul 27, 2023 | 10:50 AM
HRTKD's Avatar
HRTKD
Lead acid batteries don't like being discharged below 50%. I try to keep a battery tender on all my lead acid batteries that sit for a while.
Do you recall the ratings for the converter? When I designed my system, all over current protection was rated for 1.25 times the expected amperage.
Old Jul 28, 2023 | 04:27 AM
ksmach1's Avatar
ksmach1
I did not check the converter rating when I had the panel off.
HRTKD
All Things Towing
16
Feb 17, 2018 10:15 AM
BruceJeremy
1997 - 2003 F150
Feb 26, 2012 05:39 PM
ryutzy
1997 - 2003 F150
Jan 24, 2011 11:56 PM
IDMooseMan
All Things Towing
29
Nov 27, 2008 08:37 PM
nsshull
Aug 14, 2005 11:14 PM
