Motor ID
Old Jul 26, 2023 | 12:38 PM
Shiner1971's Avatar
Shiner1971
Motor ID
I need help trying to find out what motor this is
There's little information on the inner webs but it's in a 1975 F350 4WD rolling frame if that helps
My daughter's machinist boss said it's a 390 but with a front Oil pan sump and the weight of the Truck I would think it should be a Big Block....any help is greatly appreciated!!! Thank you
Old Jul 26, 2023 | 02:20 PM
cb_13's Avatar
cb_13
https://www.enginelabs.com/engine-te...ers-1952-1996/
It’s an FE originally from a 1974 truck. 360? 390? I would suspect with the front sump it’s from a 2wd and is in fact a 390.
Old Jul 26, 2023 | 02:38 PM
440 sixpack's Avatar
440 sixpack
The FE is a big block. measuring the stroke is the only way to know if it's a 360 or 390.
If it has a 4V on it with an iron intake most likely it's a 390 since they never made a 4V 360. , but someone could have put it on a 360.
Old Jul 27, 2023 | 06:23 AM
Shiner1971's Avatar
Shiner1971
TY
I appreciate your help, I was told it was a 460 but a druggie is responsible for that statement.
The fact that it doesn't belong belong in a 4WD is enough for me to remove it from that F350 ....
again, I thank you for the help
Old Jul 28, 2023 | 08:43 AM
beardedcap's Avatar
beardedcap
The block does belong in that truck, but it would have been a 360 FE with a rear sump pan from the factory. I'm surprised the oil pan isn't bashed in because I have a 79 F150 that had a 360 with a front sump in it when I got it and the front axle was hitting the pan
Old Jul 28, 2023 | 09:14 AM
440 sixpack
Picture looks like a rear sump, maybe not. no matter on a high boy it's easy to drop the pan. just put the right pan and pickup tube on and forget it.
BORDERBUM
Missouri Chapter
82
Jan 31, 2016 05:40 PM
Ironmancan
32
Nov 2, 2015 08:45 AM
snowracer
17
Jun 13, 2012 02:15 PM
UGA33
Projects
Jan 31, 2010 01:15 PM
Snowking
24
Aug 27, 2009 08:14 AM
