Highboy Suspension
Old Jul 24, 2023 | 02:42 PM
Aves22's Avatar
Aves22
4th Gear
Question Highboy Suspension
Hi FTE World!
My first post! I've been combing through this forum for a couple years and finally decided to make an account.
I've got a '67 F-250 2WD Camper Special and am getting ready to do a body swap onto a '71 4WD Highboy chassis with the help of a friend (more like I'll be helping him).
Anyways I was wondering if y'all had any recommendations for shocks? She will be my daily driver/adventure rig after this overhaul.
Thanks in advance!
Old Jul 24, 2023 | 03:36 PM
cstoyer's Avatar
cstoyer
Aves22
If you are not upgrading to new springs pretty much any shock of the correct length will work as they are sprung stiff so comfort is not something you will get from a shock upgrade. Keep in mind the cab will need two additional holes to mount the 2WD Cab to the 4WD chassis.
CStoyer
Old Jul 24, 2023 | 06:01 PM
Aves22's Avatar
Aves22
4th Gear
CStoyer,
This is why I am here lol
Thinking I should upgrade springs too then..
Any opinions? Best bang for buck?
Cheers
Old Jul 24, 2023 | 10:42 PM
Lrrr-RulerOfOmicronP's Avatar
I put super duty front springs and f150 rear springs on my truck to get it to ride better. It was a significant amount of work. If I was doing it over I would consider having custom springs made by a reputable company like Alcan Spring. They will not be cheap though. A couple thousand would be in the ballpark.
You may want to get it swapped and drive it to see if upgrading springs is worth it to you. My truck could not be driven down a country road without a death grip on the steering wheel going 30 mph.
Old Jul 25, 2023 | 11:15 AM
smoky_diesel's Avatar
smoky_diesel
What is you goal with the truck?
Custom modern springs will make a HUGE difference as stated above. I have Alcan custom springs on mine, love then but $1700 rear only. I did coil overs up front, same price.
Old Jul 26, 2023 | 04:02 PM
Aves22's Avatar
Aves22
4th Gear
Omicron,
Well I'm hoping since I'll have the 4WD chassis exposed it would be a little less work.
Do you mean that it would require further modification work?
I definitely don't have that kind of coin right now. Was hoping for something in the neighborhood of $400 - $600.
Old Jul 26, 2023 | 04:06 PM
Aves22's Avatar
Aves22
4th Gear
Smoky,
Goal is a comfortable and somewhat modernized daily driver with the capability to take her up the occasion forest service road to camp, or out on some stretches of BLM land. Would also like to road trip a 1000+ miles without feeling every bump in the road.
I just don't have Alcan spring money right now.
Old Jul 26, 2023 | 06:34 PM
Originally Posted by Aves22
Omicron,
To put modern springs on the truck it would take cutting off the old spring mounts and putting on new ones. Would be easier to do without the body but it is still a far amount of work.
If you use the stock springs you can always upgrade them later. There are tricks to rebuild leaf springs to ride better but I would be impressed if the rear 2-1/4 wide springs could be made to ride ok without 1000lbs in the bed.
Old Jul 26, 2023 | 07:15 PM
stpackard's Avatar
stpackard
I did battle born brakes front 99-04 super duty spring 67-77 highboy bracket and front-rear shackles. $460 bracket/shackles and price is all over on the springs, look for guys selling superduty dana 60’s and they might make a deal.
read LrrOmnicrons front springs thread and these other guys who’ve btdt.
Works well, straight forward swap. The heavier cummins Seems to not be squatting the front end and rides better than the Oe. I originally bought replacement Oe fronts from general spring and those britches squatted flat within a year. I’m guessing your closed knuckle d44 should bolt up to the leaf springs. I’m using the oe rear springs on a sterling 10.25 axle.
if you do this setup stay away from the 99 springs as it had an odd leaf wrap at the end which they fixed on the later years.
Put a little junk weight in the back and it’ll ride nice.
Old Jul 28, 2023 | 01:22 AM
RichS2659's Avatar
RichS2659
You can refresh the action of your springs by doing this:
disassemble the springs, and clean them. Then smooth and file any burrs or rough spots. Paint them and coat the load bearing surfaces with graphite. Put strips of a vinyl material between the leaves and reassemble. This is what some of the old desert racers did.
sbilby123
Nov 24, 2022 07:18 AM
Lutskas54
Jun 10, 2015 11:49 PM
dthut
Mar 19, 2015 09:12 AM
Mike's 77
Offroad & 4x4
Sep 5, 2009 12:12 AM
ford460bronco
Jul 26, 2006 08:02 PM
