(1979) Front grille shell availability
Old Jul 22, 2023 | 07:46 PM
Restorer_Frog's Avatar
Restorer_Frog
Trailering
Hello all !!
I just completed a 5 year long process of restoring my 1979 F150, the only thing missing is a decent front grille shell for it.
I went thru all the manufacturers and distributors like Dennis Carpenter, LMC, JBG, Ebay, etc ..... no one has anything left in stock...
Would anyone have a clue on where currently those could be found ??
Thanks for the input.
Phil
Old Jul 22, 2023 | 10:30 PM
buckin69bronco's Avatar
buckin69bronco
Jegs says they have it in stock but it’s a AMD one and AMD says they are out of stock so maybe call Jegs. AMD does have the chrome steel version in stock.
You could strip the anodizing off an oem one and restore/polish it. It’s hard to find someone who will anodize it again for you cause of its size though.
Old Jul 23, 2023 | 12:47 AM
78 F250 FAN's Avatar
78 F250 FAN
Dennis Carpenter has had intermittent stock over the last year or so. I just purchased one from them back in April. NPD also stocks the DC grille shell and they have had stock as well, but are currently out of stock. NPD is slightly more money than DC, but just barely.
They usually go quick, so be ready to pull the trigger when you see them in stock. Good luck.
Old Jul 23, 2023 | 03:36 PM
Restorer_Frog
Trailering
Thanks,
I will try to call Jegs on Monday morning.
I temporarily stripped the old anodizing and polished the grille to have it nickel plated because no one seems to do bright anodizing (or bright dip) anymore.
Obviously the color tone of the nickel does not really match the bright anodizing, that's why it is just a temporary solution until I can get a new one from DC or anyone else.
Old Jul 23, 2023 | 03:39 PM
Restorer_Frog
Trailering
Even though I knew DC was out of stock, I tried to call to place an "advance" order but they would'nt take it.
I will try to do the same with NPD, maybe they are setup to take such advance orders.
Thanks !!
J1nx93
Feb 12, 2010 09:36 AM
dw_wanno
Jan 14, 2010 08:33 PM
bradplock
Appearance & Dress-Up
Jul 23, 2006 09:10 PM
HzrInAz
Mar 29, 2006 10:56 PM
JAAMina
1997 - 2003 F150
Aug 4, 2003 01:16 AM
